Question about Dell 962 Photo All-In-One InkJet Printer
How to set up the dell v305 so that it works with my mac
How to make it work with my mac
Sell the mac and buy a pc
Posted on Jul 28, 2009
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 28, 2014 | Apple Computers & Internet
Locked
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Dec 04, 2012 | Apple MacBook Air
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Work around to Upgrade Mac Mini (original) OS
Can't help with te workaround, but downloading the mac version of opera browser should get you sorted.
Jul 16, 2010 | Apple Mac mini
Vivitek will not operate on Mac
Your Vivitek isn't working because it probably wont work or isn't compatible with Macs.
Just some advice: Before you buy a device check behind the box if it works with mac. There should be a picture of a mac on the back. If there is it will work with your mac.
Hope this helps!! Good luck.
Jun 25, 2009 | Apple Computers & Internet
Mac laptop will not turn on
1) Try your battery in another Mac.
2) Try a different battery in your Mac.
3) Try your power adapter on another Mac.
4) Try another power adapter on your Mac.
Go to an Apple Store if you don't have a friend you can borrow equipment from.
If your battery and power adapter work perfectly on another Mac, and working power adapters and batteries do not make your Mac turn on, then your Mac is broken internally and you need to take it to the Apple Store to get it repaired.
Nov 10, 2008 | Apple iBook Mac Notebook
"Back to my mac" stopped working
Under the Apple Menu, go to System Preferences>Internet & Network>File sharing. Look to see what is checked and not checked. It seems like you may have sharing enabled on yours in more depth than sharing is enabled on dad's. Be careful about enabling online sharing if you have any online banking or other sensitive info on that computer.
May 09, 2008 | Apple MacBook Pro Notebook
I have a MAC MINI AND MY USB MIC IS NOT WORKING ON IT.
This product uses native driver support on a Mac. No Logitech Mac Software is available or required.
It should work instantly check your sound settings the mic might be on mute or your useing wrong input on your program.
Jan 14, 2008 | Logitech USB Desktop Consumer Microphone
Dell 962 Photo All-In-One InkJet Printer Logo
191 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
