Question about Cell Phones
I haven't used my phone in a long time and when I tried to use it a message comes up saying Unreg'd sim card. Why is this and what does it mean?
  • Rod Clark May 11, 2010
    How long do you mean by "a long time" ?
  • 178 Answers
This message usually indicates that your SIM card is no longer valid. It may have expired from lack of use or if pay as you go, not adding money to it.
Posted on Jul 28, 2009
When i insert my simcard to my phone always say insert sim what should i do with my problem in my sony ericcson k610i?
If that was the message that comes out on your phone after inserting the sim card,Its just means that it is not properly inserted.Try to make sure that it was not inserted in other way,upside down.Try to rechecked the With the metal contacts facedown, align the notch on the SIM card with the notch on the SIM slot and insert the SIM card.If also means that the SIM that yuo are trying to insert has been used and has password on it.Try to insert the SIM to its original phone and unlocked SIM codes.Previous codes has been entered on it.If that is a new SIM there might be problem with the SIM slot.try another SIM card to diagnosed the real problem..Hope this helps..
Jun 20, 2011 | Computers & Internet
Limited service
"Limited Service" does come up at times on mobile phones and this is due to a limited signal. Sometimes switching off and taking out your SIM card carefully and a soft wipe can resolve other glitches.
But, if the problem continues, try using another sim of different network. if the phone still says limited service, then, it means this is a software problem. You will have to flash the phone for it to come back to normal.
Flashing means you want to reinstall the software on the phone and this will erase all the contact, messages, audio and video file you have on the phone. This done using cables software and computer.
You can take it back to samsung mobile office if it is on warranty.
Thanks.
Jun 16, 2011 | Samsung SGH-i560 Cellular Phone
Samsung 706sc incorrect usim
Incorrect Sim Message Comes means It locked to some Network,Find which Network it locked now?
Then You can get the UNLOCK CODE at here
http://www.superunlockcodes.com/samsung-v706s/rs12wp9/ and Unlock then You can use any GSM Sim Card.
Feb 13, 2011 | Samsung 706SC Cellular Phone
My phone is saying "
Hi, the message you are getting is telling you 1 of 2 things, now its either telling you that the sim card in the phone has either not been registered or it has not been topped up within a set time so its now been cancelled but if how ever the sim card is one that has been used on a regular basis then the chances are the sim card reader in the phone is now faulty.
you could try the following
1 take the sim card out of the phone, switch the phone on then switch it off again, then put the sim card back in the phone making sure its in far enough and the right way round then switch it back on and see if anything has changed.
2, try your sim card in some one else phone and if it works in their phone then you no you have got a problem with your phone
3 try another sim card in your phone making sure the sim card is from the same network as the phone is locked to,
if you try using a sim card from the wrong network it will give you the message your getting now so make sure you have got a sim from the same provider the phone is locked to.
let me know how you get on or if you need further assistance ok
please can you rate this solution as i have a whole page of unrated posts, thanks
Feb 02, 2011 | Sony Ericsson Walkman® W995 Cell Phone
My gl cell phone says unreg. sims
Hi, inside your phone, usually under the battery, will be a small card with a chip on it. This is the Sim card. The SIM card is what identifies you on the network. It has a special code that is unique to your line.
So basically, the phone is telling you that the card is unregistered: not tied to any account.
First, try taking off the back cover of your phone and removing the battery. Find the SIM card and take it out carefully. Wipe off the gold connectors and the gold part of the SIM card. Put it back in and make sure it's setting on there correctly. The gold part should touch the gold connectors, and it should sit firmly in place as to not slide around. Put the battery back in, the cover back on, and power your phone back on. See if this fixes it.
If you have another phone available that is on the same carrier as you, try your SIM card out inside that phone (just switch out temporarily). This way, you can tell whether it is the card or the phone that has a problem.
If these things don't work, call your carrier's customer service or take the phone into the store.
Feb 01, 2011 | LG Secret ? KF750 Cellular Phone
Phone keeps saying invalid sim
Messages When You Turn on the Phone
  • When turning on your phone you may find a message requiring you to take a certain action before you can use the phone. If the message says "INSERT SIM," make sure the SIM card is installed in the phone or that it hasn't become loose. The SIM card is located in the battery compartment. Remove the battery cover and the battery. The SIM card should be located near the bottom of the phone under the metal hinge. Insert or secure the SIM card with the contacts facing down, reinsert the battery and batter cover, and turn your phone on again.
    If the message reads "PHONE LOCK," the SGH U600's automatic locking function is enabled. Enter the phone's password to unlock the phone.
    When using the phone for the first time, you will be prompted to enter a PIN. The PIN is given with the SIM card for your phone. Enter the PIN number exactly as given. You may also have the "PIN Check" feature enabled on your phone, which will require you to enter the PIN every time the phone is powered on. You can turn off "PIN Check" in the "Settings" menu.
    A message asking you to enter a PUK means you attempted to enter the PIN number three times and failed. You must contact your service provider to get a PUK.
  • Read more: Samsung SGH U600 Troubleshooting ' eHow.com http://www.ehow.com/way_5408527_samsung-sgh-u600-troubleshooting.html#ixzz11rVbifG3
    Oct 09, 2010 | Samsung SGH-U600 Cellular Phone
    Most time it say insert sim
    hi,try put that sim in another phone..try see if you will still get the same message...if you get the same message, it means the sim card is bad...but if you do not get the same message you could look for a clean matterial to clean the place you normally place your sim on the phone..if this does not work also, the you will have to go see an expert to help you handle it.
    cheers.
    Jul 17, 2010 | Sony Ericsson K750i Cellular Phone
    I have a sony ericsson cyber-shot 5.2 mega pixels and when i turn it on it keeps coming up on the scene saying ' insert sim card or view a demo of the phone first' when the sim card is in the right way and...
    hi, have you tried inserting another sim card? try inserting another one and if you still get the same message it means the the memory space of the phone might be faulty...if after inserting another sim and it worked properly, it means that the sim card signal is week..it means you have to contact your service provider.
    Jul 14, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
    Invalid sim
    Invalid SIM and Unregistered SIM are two different problems. Invalid SIM means the phone is locked to a certain company and you are trying to use a SIM card for another company. Unregistered SIM means the SIM card you are using is not active and you need to contact your service provider to get it activated. In order to unlock the phone so you can use anyone's SIM, you must contact the provider that the phone is locked to.
    Apr 22, 2009 | Cell Phones
    Keeps sending mext text message error
    the phone could be tapped in some way meaning some body could of hacked thoguth the imei number and that means when a message gets sent to your phone and u reply they can be taking your credit this might be the case but it has been known
    Jan 13, 2008 | Motorola Mobility RAZR V3
    Cell Phones Logo
    32 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
