Question about Nakajima AE-710 Typewriter
HOW DO I INSTALL THE CORRECTION RIBBON?? - Nakajima AE-710 Typewriter
  • Nakajima Master
  • 3,594 Answers
First be sure tou have a dry L/O tape Gen. Ribbon T355 or eqiv., put the full spool on the L. side of the carrier, for ease open the printwheel as if you were going to change it.
install around the slacker wire, thru the guides with the dull dide of the tapt towards the platen and to the take up spindel.
DickyO
Posted on Jul 29, 2009
CORRECTION RIBBON
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Office Equipment & Supplies
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
I have a gx6750 correcting typewriter. The problem is, the correcting part of it does not work. I am wondering if the correctable ribbon indicates "correctable" on the cartridge or not. I am...
A correctable ribbon should be correctable. Is the ribbon being lifted up high enough to correct?
Is there any letters on the correction ribbon and is the ribbon installed correctly? Old ribbons lose their tackiness over time, try advancing the ribbon by hand to get to fresher ribbon.
Jul 08, 2011 | Brother Office Equipment & Supplies
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
Installed new ribbon. appears correctly installed.
There is probably a fold in the ribbon usually the bottom, reinstall it and be vsure it is flat between the guides.
DickyO
Oct 02, 2009 | Lexmark Wheelwriter 15 Series II...
Replacement of correction tape
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
GL
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Replaced Typewriter Ribbon & Now Correction Tape doesn't work
Is the ribbon that you installed a correctable one? It should have a yellow or orange knob to turn it. If that knob is blue, you installed a multistrike or non-correctable ribbon.
The only other thing is you have the correction tape in backwards
Jan 12, 2009 | Brother SX-4000 Typewriter
Correction ribbon
make it sure that the correcting ribbon correct insert to the guide of the ribbon push it then you feel lock , test correcting not jumping ribbon case , then ok.
Dec 11, 2007 | Brother GX-6750 Typewriter
Nakajima AE-710 Typewriter Logo
106 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
