Question about Raymarine Computers & Internet
Its the same here can anyone help?
It comes up and says cant find compatible 3d drive
I have a Designer 1 with the USB port, & I have the 3D embroidery system. Apparently the two are not compatible, is that true?
They should be compatible. You may have to sign on and get an update at the Viking site - http://www.husqvarnaviking.com/us An update would allow you to change the Send configuration within 3D to the appropriate machine.
Oct 06, 2013 | Husqvarna Viking Designer 1 Embroidery Arm...
Piracy check failed
Try opening the game in compatability mode.
Jun 23, 2013 | Sonic 3D Blast for Windows
How can enable 3d on philips led 40pfl8605h?
Do you have the PTA02 accessory for the TV? This is a USB 3D transmitter and comes with 2 pairs of Active 3D glasses. The screen of the 40PFL8605H is not a 3D TV by itself.
Once you have the accessory plugged in, you may need to wait for the software to be installed on your TV before you can watch 3D content. See the manual for the TV for more information: http://download.p4c.philips.com/files/4/40pfl8605h_12/40pfl8605h_12_dfu_eng.pdf . This is on page 73 of the PDF.
I hope this helps. If you have the 3D accessory plugged in, try turning off the TV and turning it back on if the software did not install properly. The final thing to check is the "codecs" for your 3D movies on the USB stick. Make sure that they are compatible with the TV.
Apr 19, 2013 | Philips Televison & Video
I cant play some 3D disc, for example ,2010 Fifa world Cup Film.
Please check the regional code given at the back of DVD cover. It should be compatible with the ones given in the manual of your DVD player. If not compatible the DVD will not be played.
Aug 07, 2011 | Samsung BD-C5900 Blu-ray 3D Player
I cant play 3d games
Try earlier versions of 3D games.
Your computer is a somewhat older model. So try playing 3D games released around 2000-2002.
Try NFS 6 or lower, GTA version 2, IGI 1 & 2 etc.
If even they don't work, try replacing the VGA card with a compatible but better VGA card (Cards from nVidia might be a good option).
Jul 26, 2011 | Intel Compaq EVO Pentium 4 1.7GHz / 256MB...
I have had the 3d deck version for some time witch i ran on an older computer with windows xp but i cant install it on my windows 7 ??????
Have you tried to install it in WinXP compatibility mode? Right click on the install exe and then select properties at the bottom. Click on the Compatibility tab and then select Compatibility Mode and select run in XP mode.
Good luck
May 01, 2011 | Sierra 3D Deck 3.0
I must be desperate if i'm trying to get help *here*.. i've only ever seen noobs with 'where's the trash folder' or 'i wanna crack '.. but i'm pissed ..i bought a game called 'egames pinball' and it...
I would right click on the program and run it in compatibility mode for the operating system it was designed to run on. I would also try to update my graphics card drivers.
Mar 29, 2011 | Computers & Internet
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
Minimum Requirements:
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
Recommended Requirements:
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Computers & Internet Logo
24 people viewed this question
Top Raymarine Computers & Internet Experts
David Payne
David Payne
Are you a Raymarine Computer and Internet Expert? Answer questions, earn points and help others
