Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Need to know the size to use to gap the coil and flywheel
    Scholar:
  • 173 Answers
The gap will vary, depending on engine wear.
If you have a ' feeler gauge', it won't take you long before it runs beautifully.
That's it,
oh and, don't forget to rate:)
Posted on Jul 28, 2009
Can you please tell me the air gap between coil and flywheel on a sthill chain saw and flywheel nut size thanks
Use a flexible feeler gauge to measure the gap. The magneto gap for any 2-cycle engine chain saw should 12-18 thousands of an inch. The gap is much less important than simply NOT HITTING the coil frame at any point on the flywheel. The nut is probably metric but I cannot tell you what size it should be. BE CAREFUL! Some chain saws have LEFT HANDED THREADS on such shafts! But you can usually tell by studying the protruding threads at the nut ... if there are any!
Apr 26, 2017 | Garden
Coil air gap setting on stihl BG 85 C blower
The box the coil came in should have a paper card for setting the gap. It isnt written on the paper....it is the paper! Put it between the coil and the flywheel and bolt it up! If there isnt a gap paper in the box use a paper business card in its place. The stock gap size of 0.0125 inches is virtually the same as the 12 point paper used for a business cards in the US. I would recommend checking spark before reassembly just to be sure everything is right. Be safe and good luck!
Mar 08, 2015 | Stihl Garden
Hi , I have an GCV 160 Lawmower from 2005. Trying to statr it pops and give bangs, but will not run. How likely is it that the flywheel or ignitionmodule is defect?? I can see that scraping marks on...
The legs of the ignition module should not touch the flywheel. It needs to be set to the proper "air-gap." Get a standard sized business card, fold it in two to use as your "gap." Loosen the screws on the coil and turn the flywheel to where the magnets inside it are pulling on the legs of the coil. Put the card in between them, letting go of the coil and retighten the screws. Most proper "air-gaps" are between .010" - .014". A business card is about .010" but will compress in size, when folded in two with pressure from the coil legs on it. Post back if more help is needed.
Apr 15, 2011 | Honda Garden
Oh160170048F engine I removed the coil, now i don't know what the gap should be??
The air gap from the ignition module (coil) to the flywheel can be set with a clean and dry business card. Set the gap to maximum and snug down the bolts. Then rotate the flywheel around so that the magnet is positioned directly in front of the module. Place a business card in the gap, and loosen the bolts. The module will be drawn to the magnet. Tighten the bolts and rotate the flywheel to remove the card.
Dec 02, 2010 | Garden
My fs55r wont start - got carb kit, new filter and sparkplur what next?
You need to make sure it is getting a nice strong spark. The electronic solid state ignition control module (coil) controls this and the contact legs on it have to be gapped about .010-.012" from the magnets on the flywheel. This goes on under the front engine cover. First, check for a nice blue spark. If it is weak or yellow, the coil needs adjustment. They fail rarely. A standard business card is about the proper thickness to produce the "air-gap" needed to create a a good spark.Also, make sure the plug has the correct gap on it.
If you have to check the coil, the front engine cover will have to be removed and moved forward to access it.Underneath the cover is the starter/recoil unit and under that is the flywheel and the coil. The coil will be attatched to the engine cylinder with a couple Torx screws about size T-15 or T-20.
Nov 06, 2010 | Garden
I am replacing a bad coil in my Echo SMR 2100. I need to know the air gap between the coil and the flywheel.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH
Aug 06, 2010 | Echo Garden
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
Weak spark
check the gap between flywheel and coil should be 010.gap.allso check magnet on flywheel.let me know what you find out.o if spark still weak change coil.let me know.ok
Jul 23, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
235 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
