SOURCE: Have a Panasonic Workio 8020 machine, is showing
Change copier to Fax mode - Function button no. 7 (set mode) and then No.1 (user parameters)
SOURCE: xerox machine not working
if this is concerning a panasonic 8020 then the tray lift mechanism is faulty, a modified replacement will need to be fitted.
SOURCE: error E01-01 panasonic dp-8020
charging error.clean the charging throughly with alcohol or spirit
SOURCE: sir, my photostate machine showing add paper
u have to check the interlock switch (front door switch).it is not working ,.either u have replace it or just short it with a wire and ola
SOURCE: my photocopier machine panasonic 8020
u have to check the front door interlock switch.this is a common problem with the panasonic copiers .if u have a new interlock switch then replace it,if not then short ckt the same with the help pf a wire and thats all
