SOURCE: ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
SOURCE: Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
SOURCE: panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
