I have an older model MP130 and have a service error 5100. The printer will not work at all. What can I do to fix this and/or do I need to take it in for service? Thank you.
    President:
  • 1,996 Answers
Go to Canon support here and enter "service error 5100" into the search box; you will get detailed instructions for correcting this error condition. (If you click on highlighted results, details ensue.)
The general instructions are as follows:
Solutions for service error 5100
Issue: ERROR: Service error XXXX appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Remove foreign object from paper feed area (MP130)
5. The MP130 may require repair
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 28, 2009
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Error 5100
The 5100 error usually shows up when your computer system files are damaged. There is about a 94% chance that this is the problem.
Follow these steps to fix the issue:
Step 1: Download and install Error 5100 Repair Tool
Step 2: Click the Scan Button
Step 3: Click the Fix Button and you're done.
Hope this works for you!
HelpDeskMan
May 21, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Error 5200
The 5200 error usually shows up when your computer system files are damaged. There is about a 94% chance that this is the problem.
HelpDeskMan
May 17, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
May 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP130 error 5100
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge jammed
This was given to me to fix error 5100, and worked:
Press Menu, then Scan, Copy, Scan toenter Service Mode
Press the + button until you arrive atNVRAM ACCESS, press OK
Use the + or - buttons to reach ABS-MLEVEL, press OK
Set the level on zero and press OK
Use +/- to reach ABS-P, press OK
Set this level to zero and press OK
Press STOP to exit the menu
Switch off and restart the printer.
Mar 18, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 code pixma MP130
Hi You can Try have a go
Error Code 5100
Solution 1:
Solution 2:
Jul 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
167 people viewed this question
jasbo
jasbo
