Question about Sunbeam 3802 Toast Logic 2-Slice Toaster
Toast rack won't stay down, and I can't figure out how to get inside to look at it.
Simple, hold it down all the way, for at least 3 to 5 minutes, with nothing in it.  Then release it, and try it again.  It should work.
Posted on Nov 07, 2009
  • wcreevey Jun 22, 2011
    Did not work!
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
For some reason, the mechanism to hold down the toast is not working and it keep popping up as if it is stuck on the ''cancel'' function.
When this happens it is usually due to the fact that the electronics inside the unit has failed, and will not activate the hold in relay.
Time for a new one. Repair may be an option, but probably not an ecconomic repair.
Jan 22, 2010 | Kitchen Appliances - Others
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
My roof rack on my 97 gmc yukon has pulled out of the roof. There are small "1/4 inch" posts that go through the roof but I can't figure out how they stay in there.
probably a rivet need a special tool for that if it were me the roof rack would have been the first thing i took off but that's me
Apr 27, 2009 | 1997 GMC Yukon
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Tape rack stayed open
I just experienced the same problem, but it took me 10 minutes to get it working again. When you look inside the tape rack, you see on the left side in the middle a little mechanical arm which you can press down for about 1cm when you release it again the rack opens completely Good luck Robert
Jul 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
Sunbeam 3802 Toast Logic 2-Slice Toaster Logo
239 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
