Question about Epson Perfection 3200 Photo Flatbed Scanner
My epson 3200 photo scanner won't initialize. the power turns on and the scanner tries to move but only moves a little bit. the error light comes on green but beeps 3 or 4 times then goes to red. i tried both firewire and USB connectors.
  • dsm02 Jul 28, 2009
    no the scanner is in the unlock position. i tried that as well. i'm using photoshop CS2 with mac os X 10.5.
    there hasn't been a problem up until this time.
  • hoplex May 11, 2010
    Which operating System are you using and when did this started happening. How old is the scanner ?
  • 724 Answers
Loock for the transport locking device
Posted on Jul 28, 2009
  • tommya300
    tommya300 Jul 29, 2009
    did you ever remove the glass to clean it.
    Reason I ask is that I had worked on an all in on that stopped working on startup the lamp would warm up and jug and then shut down and have an error message relating to a jammed head.
    I unpluged it removed the glass and moved the head by hand it felt a little stiff and then it was free I put it together and plugged it in and watched the head move back in position as this was happening I figured on seeing if by constanly pressing the number pad and the statr scan button I might confuse the programming to a reset. It was a last ditched effort did not think I fixed anything at first. To my supprise it ran with no error messages. Technical no susessful yea it hs been 2 weeks now and it is still working OK
  • 59 Answers
Is the scanner lock switch engaged on the bottom of the scanner ?
  • jared voulo Jul 28, 2009
    does the scanner have external power or is it powered by the usb bus ?
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Carriage won't move
Are you getting an error message on the computer? If not replace the scanner.
Apr 29, 2012 | Epson Perfection 4180 Photo Flatbed...
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
Scanner Powers up - does not intiate, cannot be accessed by PC
Power everything down, computer and scanner. Make sure your scanner is connected to the AC wall outlet, and to the pc. Then turn on your computer. Reinstall the driver and software by following this link http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=kVFQIoh3k1nuobYrVg0U002FnSoPZ+wxlW6UdEWrYhTx6DwU003D&tc=6 And download the latest update (2007) and you should be good to go
Nov 23, 2008 | Epson Perfection 4180 Photo Flatbed...
Red light error
OFF the printer.open the top cover whole scanner unit .then look at the black base where usually cartridge moves when the printer is ON when you give printouts..press that black base and it will move little bit down .that whole black base comes little bit up due to some reason and when the cartridge holder moves from left to right for its internal allignments/adjustments it clashes that part somewhere and make such noices.and gives the service error..just press that whole 7- 8 inches base where the cartridge moves slowly ,carefully and firmly.then ON the printer and check.do it again if it does not becomes ok after first time.
rate the solution if it helps
thanks.
Nov 04, 2008 | Epson Stylus Photo RX500 Printer
Need help
either its the error in your circuit board so call the epson service center.
or try this
OFF the printer.open the top cover whole scanner unit .then look at the black base where usually cartridge moves when the printer is ON when you give printouts..press that black base and it will move little bit down .that whole black base comes little bit up due to some reason and when the cartridge holder moves from left to right for its internal allignments/adjustments it clashes that part somewhere and make such noices.and gives the service error..just press that whole 7- 8 inches base where the cartridge moves slowly ,carefully and firmly.then ON the printer and check.do it again if it does not becomes ok after first time. hope this helps........
thanks.
Sep 25, 2008 | Epson Stylus Photo RX500 Printer
Epson RX 500 stopped working
thanks.
Aug 23, 2008 | Epson Stylus Photo RX500 Printer
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
CanoScan 5000F - Scanner bar is stuck
hi all;
i fixed it by taking the thing apart, pushing the scanner head (the block that is stuck-- that normally moves) back to the starting position. Make sure its snug at the end, a little bit off and you'll be putting it have to take it apart and back together a second time. There's a mirco swtich in there somewhere, and you need to make sure its pressed...
reconstruct, and hey presto, a working scanner! this also worked for my epson 1250 that got stuck once.
Easy as a section of gateaux.
Oct 04, 2007 | Canon CanoScan D660U Flatbed Scanner
Scanner
If the unit is in warranty, get Epson out to it. If not check the simple things like making sure the head lock is not on. Look to see if the scanner head starts to move at all when you power up the unit. If the head does not move at all or makes an unusual noise, chances are the unit is complaining that the head is stuck or requires too much effort to move it. Other possibilities include a communication error between scanner and main board of the SPC or SPC and your computer - indicates broken connection or bad USB cable. POssibly a fault with the mainboard of the SPC itself. Error ?Cause *Remedy Scanner error ? Lamp has burnt out. * Replace the scanner lamp. ? Power is turned on without unlocking the scanner. * Unlock the CR. ? The scanner carriage is interfering with any other part. * Remove the obstacle. * Replace the scanner carriage unit.
Jun 22, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson Perfection 3200 Photo Flatbed Scanner Logo
482 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
