Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Circuit board has been changed and now I get an error message F5
The oven was not heating up. I was getting a beeping sound at mid cycle and then shutting off. The clock was not reading. The circuit board was replaced. Clock works but the same thing happens the oven will shut off and I get a beeping noise with a error message F5. What does that mean.
GO TO http://www.repairclinic.com/0078.asp THEY HAVE ALL THE FAULT CODES. I WAS ABLE TO FIX MY JENN AIR WITH THIS LIST. THE PART WAS AROUND 20.00 REPLACED IN ABOUT 20 MIN
Posted on Sep 15, 2009
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
I was using the Self Clean on the oven after a couple of hours I got an error message E1 and F5 - and the oven door is locked. I have no idea what that means or how to get the door open again. I tried...
Hello there and thank you for choosing fixya
Ok before i get into the error codes just a few words here about the self cleaning feature
This the feature that is the most harsh on these ovens due to the extremly high temperatures that is produced then this can and will cause serious problems if not done correctly
I know that people like this feature but i highly suggest that if you are going to use it please try to get the oven as clean as possiable before using this feature this helps the cleaning cycle tremendously ok?
Now for the error code
the e1 error dode is due to the door being locked so to repair this you need to unplug the oven and leave it sit for at least 1 hour this allows for the internal reset feature to reset the oven controle
after the hour is over plug it back in and in 1 to 5 min you may hear a audiable beep or click if so simply press the cancel button and attempt to open the door if so great you should be ok
Now for the bad one
The F5 code is due to the oven control sensing the extreem heat during self cleaning
and sensing that the controls are not controlling the temperature during cleaning which is a bad thing this can and will cause the control board to fail and once again due to the excessive heat
So hopefully once the oven has been unplugged for the hour and reset you should be allright but if not than you do have a bigger problem meaning that your controle board is shot ok?
Please keep me posted on how this is going so i can send you more information on this
Best regards Mike
Feb 18, 2011 | Whirlpool Ovens
I am having the same problem that many others are. My screen went blank and when the buttons are pushed they just beep. This sounds as if it is some sort of malfunction within the circuit board? I plan to...
It is and you are doing what you should. We know that a lot of these problems are being caused by the heat from a self-cleaning cycle rising up into the circuit board. I get a lot of these problems right after someone self-cleaned their oven, although it can fail completely months after the cleaning cycle damaged the board. So in the future try and use the self-clean cycle very sparingly and set the timer to clean for only two hours if it will allow it. My best advice is to not use the self-cleaning clycle, use aluminum foil in the oven floor, and hand clean the door and walls as you use it. Do not use oven cleaner on this as most of the cleaners will damage the self-cleaning oven liners. Change the aluminum foil when it gets dirty and never self clean with the aluminum foil in the oven. Good Luck, Appliance Specialists
Jan 05, 2010 | Whirlpool GBD307PDS Electric Double Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven won't heat after E5F5 error messages
Unfortunatley on that model the keypad is a bit spendy. It's around $100.00 Here is the link to what part it is. You maybe can search around and get it a little cheaper. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KEBC147KBL04&productCategoryId=0125300&brandId=0593&modelName=BUILT-IN-OVEN---ELECTRIC&diagramPageId=00002&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0410072&backToLink=Return%20to%20Sub%20Components%20list
Apr 19, 2009 | Kitchen Ranges
Maytag Oven Error Code
main board bad or sensor .more likely board though
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
All Surface elements are dead
Sounds like you might have a bad oven surface control board also called power board. The part # is 316239400. It is located on the left hand side about mid way down on the back of the oven. First, disconnect power and make sure all connections on board are tight. Plug back in and make sure you have power to that board if possible with a meter. If all check ok then the board is bad.
Oct 05, 2007 | KitchenAid KESC307 Electric Kitchen Range
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
402 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
