You might try one of the two manuals here:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/1430.html
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/14_5.html
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: My Sears Kenmore 1751 siz-zag sewing maching will
these older cam machines have grease in then that can jam up the cams if you can get the covers off soak the machine with wd-40 and play with the reverse and stitch length if it breaks free try and soak up as much of the wd-40 as you can and then put sewing machine oil in the machine
SOURCE: I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
SOURCE: sears model 13 kenmore won't sew forward
its not easy sewing left handed is it? i think that oil has got into the switch and you have lost forwards drive now,,give it a good wiggel about till it clears it out, if it was working ok the last time you used it its just got a bit sticky thats all,,,i hope you used a light oil?
