I can't adjust the horizonal on my 17'' kogi to fit my screen
I have tried the adjustments on monitor to no avail.
  • Hank May 11, 2010
    Hi, What graphics are you running? Sometimes you can adjust it from your graphics software. Hank
    President:
  • 2,992 Answers
You may have case of bad solder joints developing in the monitor's horizontal circuit. Many parts get pretty hot and this can lead to connections failing over time. Or some part may have failed and is causing the problem. If you or someone you know has the skills to do electronic soldering, you could check the solder joints and repair any that look questionable. Otherwise, you'd be better off replacing the monitor. It's difficult today to find a service shop that will attempt a monitor repair (lack of service information and parts availability problems), and the labor cost will be high if you do find one. New LCD monitors are quite inexpensive now, especially if you shop online.
Posted on Jul 30, 2009
Screen not fit to the monitor size
try the controls available on the moniter front as i do not know anout this model.
you shouls be able to adjust and cannot harm anything.
Aug 29, 2012 | BenQ V773 17" CRT Monitor
My computer screen is going down
Sounds like you need to do a realignment to your picture on your monitor, look on the front panel on you monitor for a menu button, press it, just once wait for the menu to come up, the you should see arrow keys next to the menu button, scrowl down until you find Horizonal adjust, they may call it something else, follow the instructions on the screen to make the nessary adjustments, you can adjust brightness and contrast also. Thanks Rick
Jul 31, 2011 | LG Studioworks 700S 17" CRT Monitor
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Stretched picture
Go to "control panel" dbl clk "display" then adjust "Resoloution" example:724x1028 something that looks like that,just keep trying sizes until u get what u want. Goodluck!
May 28, 2010 | Compaq 17" Flat Screen CRT Monitor
I just hoolked up a Kogi l7 eh 17
It may be that your video card is too old, that probably is the problem since you are running Windows 2k. If not open up your monitor's menu and see if you can manually change the monitor's resolution. Newer monitors do that.
Apr 12, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Looking for the three cables needed for a 17" KOGI L7CH LCD monitor. Where can I find these, please.
You need a signal cable, an audio cable and the power adapter. The first two are standard cables available at any retailer of computers and monitors or online. The signal cable is the type that has 15-pin "D-sub" connectors on each end. The audio cable will have a mini-stereo plug on each end. The power adapter is available from several online sources. There's an eBay auction currently running for the adapter you need.
Jun 15, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi 17'' flat screen monitor
there are four(4) buttons on your monitor to the left of the on/off switch.
Press the first one to the left of the off switch, which will bring up a menu, so you can select
bright or volume, screen size, etc; Next, there are two (2) buttons to the left of the first left button
that you can push to adjust brightness, size, vertical, etc;
Apr 03, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My Kogi 17 inch monitor illuminates for 2 seconds and then the light goes out. The monitor is still on but hard to see. Each time you power cycle the monitor, the display appears normal for exactly 2...
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, even after the display going off, the monitor is till on;
  • LCD screen (possibly) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen. If with the use of the flashlight a darker semblance of the desktop could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
On screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
Mar 07, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
