Question about Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum
Power cut out during cleaning - Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum
    Problem Solver:
  • 9 Answers
1 could have hit the thermal shut off. if it gets to hot they shut off, or it could be the cord some times they just go bad or it could be something else. Good Luck!
Posted on Jul 28, 2009
Power cuts out but light is still on so has battery power
Hi Kimberly, it's Jack at Dyson.
If your DC44 doesn't seem to be working correctly, our experts would be happy to help diagnose the cause of the issue with some troubleshooting checks.
When you have your machine fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 05, 2014 | Dyson DC44 Animal Cordless Vacuum
Dyson dc30 switch suddenly not working properly
Sounds like the switch is bad. If it's not still under warranty I'd look up a replacement part.
http://www.dyson.com/parts.aspx
Nov 23, 2013 | Dyson DC16 Root 6 Bagless Handheld...
Trigger switch cuts off during use
make sure the filter is washed thoroughly. I have/had the same problem and washing the filter helps a lot - it cuts off if overheating....and avoid picking up really fine dust like after drilling picture hook holes...
Feb 02, 2013 | Dyson DC34 Bagless Cordless Hand Vac -...
No power to Dyson checked plug & fuse both ok any Ideas
Hi its Darran at Dyson.
If the machine cut out during use this will be the thermal cut out. This is caused by the motor becoming too hot during use, due to a blockage or a dirty filter. full details on how to resolve this can be found on our website at www.dyson.com. Simply click on Support and you will find all the info you need.
If the machine has cut out and wont switch on again after being left for a few hours, it sounds like an engineer will be required to inspect and repair the machine. You can contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Mar 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The motor overheats and shuts off. This annoying because it has done it at least 5 times today during normal vacuuming. It shuts off easily when you use the hose and canister to clean the steps or around...
Almost all vacuum cleaners have a thermal cut-out, which operates when the machine gets too hot and resets automatically when it cools down. Overheating is almost always caused by a blockage. Either the filters need cleaning or changing, or there's an obstruction somewhere in the pipe-work. Make sure there's good clear air flow and your problem should be solved. Good luck!
Jul 17, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Power Loss - Suction Loss
Hi
Its cutting out because its overheating.
Change the filters and check the base and the hose for blockages
Feb 14, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power on
Hello markswifey92. Check your AC cord & plug. There maybe a wire broken. Be careful of exposed wire. #2 May be a bad power switch. Please inform me of the results and I will provide repair steps. Please include Mgfr, model & serial#. Good luck.
Sep 27, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Suddenly power switch off, replace fuse stil same
dyson vacuums have a cut of switch on the motor when the motor gets hot it will cut out you need to clean both cyclone and filters and try again if you don't have any success then it is looking like replacement motor or replacement cut out switch
Sep 02, 2008 | Dyson Vacuums
Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum Logo
148 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
