Question about Hotpoint Microwave Ovens
Some of the buttons on our microwave electronic pad are no longer working.Can I do anything or do I need a repairman?
    New Friend:
  • 49 Answers
They may not be fixable, depending on the type of buttons used. Many devices use a 'snap dome' switch, which is a little metal disk that 'pops' in and out like an oil can. Problem is, sometimes they get pushed too hard, or just get old, and they stay in the 'popped' position. It is sometimes possible to repair them, often not. A repairman is likely to charge more than the cost of a new one: they'd have to take the thing pretty much apart to get to it, and then may not be able to fix it.
Sorry it's not much help.
Posted on Jul 28, 2009
Microwave does not work
Need more information, like brand and model number. Also, does the inside cavity light go out when you close the door? If not, your problem is probably a bad door switch. If it DOES go out, but the microwave doesn't do anything when you press START, then you may have a bad keypad, control board, or it may still be a bad door switch (a different door switch - there are 3 or 4 door switches in most (all?) microwave ovens). Probably need to have a professional microwave repairman look at it.
Oct 17, 2014 | Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
When I boil water on the stove top, the electronic buttons on the microwave do not work. After a period of about week the electronic buttons work again. A repairman said I need a new door for $325.00. ...
CONTACT LG FACTORY TECHNICAL DEPTN, ASK IF THERE IS A SERVICE FLASH ON THIS MODEL OR INSULATION TO KEEP THE CONTROL PAD FROM FILTERING WATER STEAM..
Feb 18, 2011 | LG LMVM2075 Microwave Oven
Does anyone know where I can get a replacement for the Button Door Release (PS 2046604) for a Jenn-Air M169w? Its an older model, from about 1996, and the few listings I've found for it say the part is no...
You are correct; the part that you are looking for is no longer available. I think that this has to do with the great amount of electronics that come from China and Japan. It is cheaper to replace an electronic unit than to repair. I should know, I have been a repairman for 30 years. People just don’t even think about repairing an item anymore. They just want a new one.
I am sorry that I could not help.
asnowman
Mar 19, 2010 | Microwave Ovens
My microwave suddenly stopped heating anything, kenmore 721.62629200
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
If there is no noise at all the fuse may need to be replaced.
UNPLUG YOUR MICROWAVE BEFORE WORKING ON IT...
Read the owners manual to locate the fuse, remove it and take it to a parts supply store. Let the technicians test the fuse for you. If ti is bad, they can give you a new fuse to install. If it is not the fuse, they can recommend a reputable repairman to service your microwave.
Feb 05, 2010 | Microwave Ovens
Buttons don't work
Hello there
Normally this is a sign of the controle pad malfunctioning wich is very common you will have to replace the controle pad
If you have your warranty still use it
If not the pad can be replaced it will cost about 30 dollars for the part and if a repairman does the job ait will cost about 80 dollars for him to do the job
ok
Best regards richard
Nov 27, 2009 | Microwave Ovens
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
Microwave locked
Try unplugging it for 15 to 20 sec. Still won't work? Try unplugging longer.
Jan 12, 2008 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
