Question about Mongoose Exile 26 Men's Full-Suspension Mountain Bike
Front shifter problems
On my Mongoose bike, the shifters are in the handgrips. The hand grips tend to slide outward and mess up the shifting mechanism.
  • 162 Answers
Take the grips off and wrap some friction tape around the handlebars about half to three quarters the length of the grip from the end of the bars. then put the grips back on. shouldn't need more than 3 layers of tape
Posted on Jul 31, 2009
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Grip shift 30 will not hold
Either gear cable is too tight or shifter is worn. Has cable been recently adjusted? if so, it needs to be readjusted. More likely, the shifter is worn so that the cogs aren't grabbing the tooth for high gear. It may just need to be cleaned or replaced. A good how-to website is "sheltonbrown.com". Your local bike shop can also assist
Oct 19, 2014 | bike.com PDW Dapper Dan Lock On Standard...
Bought a 26" Mongoose Detour
For the gear problem.Find the shifter.Use a pair of pliers and loosen the nut where the cable is passing through the shifter.Now withe the pliers pull the cable tight.Very tight.Spray the shifter with WD-40.That should fix it.
For the front rim,tighten all the spokes.Pliers will work,but a spoke too; will make the job faster.
May 16, 2011 | Mongoose Cycling
I have just bought a 1995 Specialized Hardrock GSX. It comes with a Sram Grip Shift MRX 100. I want to replace the handlebar grips, but am confused with so many offerings. Please provide me with product...
As anything that contacts your hands and controls the shifting is a personal preference I would advise you to find a real bike shop and discuss it with them. You can also look at and manipulate other brands and models before committing.
Jan 17, 2011 | Sram Cycling
I dont know how to put the gear switcher back on
The gear switcher (cycling terminology: Shifter) should be attached via a band with a simple bolt through it. The shifter will attach to the handlebar (right side for rear shifter/ left side for front shifter).
coachphil.jpg If you have shifters that are shaped like a barrel as in the picture, then you have to remove the grip on the side you will install the shifter. slide the shifter onto the bar and tighten the set screw in the housing (should be just back of where the cable comes out). Reinstall the grip and there you go.
This is a simple proceedure, however if things are not tightened properly you can get into an accident, for this reason I would recommend taking the bike to a bike shop and having them reinstall the shifter and make sure that everything is safe and functioning properly.
Final Note: If your shifter was on the bike and functioning properly and fell off, then you need to go into a bike shop. The shifter has something broken and either needs to be replaced or fixed. Shifters do not just fall off.
Nov 19, 2010 | Jeep Cycling
How do I fix the grip shift ? The piece that you turn to shift gears will not click into place. It slides back to first gear.
on the top of your grip shift there will be a slot for your shifter cable to connect. there should be a bolt there as a tensioner as well as on shifter itself. these may have to be tightened because it sounds as if they are loose.
Aug 24, 2010 | Schwinn High Timber Girls' Mountain Bike...
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
Need to adjust the front derailer, it won't change gears
There are two small screws which control the travel limits for derailer systems. Normally located top left of front mechanism when viewed from side. Adjust to allow travel within limits of gearing. Make sure that cable is not slack when in low gear position.
Jun 10, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Chain Rubbing
Kevin:
I'm not sure if it's rubbing on the front or rear shifter. The front is more common, so I'll try that first. The shifter pushes the chain left (lower gear) and right (higher gear) to shift - if it's rubbing, then it may be trying to shift. If it can't be fixed by using the shifter directly, which you've probably tried already, you'll probably need to adjust the cable.
There are two ways to adjust the cable, with a barrel adjuster and with a wrench. The barrel is the piece between the cable housing (plastic tube the cable goes through, usually black) and the shifter. If it's the front shifter, it will be the one one the left of your handlebars. Try 'unscrewing' the barrel a little bit at a time. It may be off in either direction, but 'unscrewing' will tighten the cable, and since you bought the bike in the summer, it's likely that the cable has stretched and become loose since then.
Count the number of turns and try only 1 at a time, watching to see if the rubbing goes away. If not, return it to where it was by turning the same number of turns the other way.
Without knowing whether it's the front or rear, which gear it's in and which side it's rubbing on, this is my best answer. Let me know and I'll adjust my advice!
Dan
Nov 19, 2008 | Mongoose Exile 26 Men's Full-Suspension...
Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
348 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
