Question about Samsung DLP HL-P5663W 56" TV
My samsung dlp 6167 freezes up, but now doesn't turn on at all.
My samsung dlp tv first had the lamp go out at 6600 hours on a 4.5 year old tv. i replaced it and worked good for a while then it began freezing up on me. the tv then would not start unless i unplugged it and turned it on tv first then time warner cable box. now it doesn't turn on at all...it also would turn off for no reason if you had not changed the channel in an hour or so. i am fed up because i asked samsung about this and they said this was not a problem with their tv's but it is obviously affecting a lot of owners.
  • Dennis Schmidt Jul 28, 2009
    that doesn't help much...the tv also doesn't make the sound when you turn on a samsung...that little chime sound letting you know its powering up..
  • Dennis Schmidt Jul 30, 2009
    i tried leaving it off for over 12 hours and now it still doesn't turn on...why is it that you feel its the ballast fan...something is not turning on properly because there is no start up chime or picture at all
    Brigadier General:
  • 8,619 Answers
Hi
The issue is occurring due to overheating. This has happened due to ballast fans not working or due to swollen capacitors on the main power supply board of the TV. These capacitors swell due to overheating, and we'll need to replace these cap.s. Unplug the unit from the power socket for 8-12 hrs. And after this turn on your TV, if you can see any picture on your TV then quickly go to service index menu of your TV.
You can go to service index mode of your TV by following the procedure.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the Channel up or Channel down to select the category.
5. Use the Volume up or down to enter the category.
Note--Some models may not have Category Selection.
6. Use the 'Channel up or down buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Just in case you have to go back, write all the settings you can see on the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 28, 2009
  • Rylee Smith
    Rylee Smith Jul 30, 2009
    As advised earlier the issue is occurring due to overheating. If you think the ballast fans are working fine and there are no capacitors on the main power supply board of the TV, then you need to replace the Power Supply Board on the TV.
    Thanks
    Rylee
  • 5,501 Answers
I have a Samsung "61". Mine would also lose sound when it went through one of its moods. We got about 6600 hours on the first bulb, 9000 hours on the second, and have about 9000 on third and holding. I kept pressing the "ON' button and killed the cable feed while doing it. The TV "Temp" light would keep showing up as well as the lamp button flashing.
After a battle of "wills" the human race won. Since the lamp is sensitive to cool downs and we live in a cold climate, we just leave it on. The rear of the set is subject to "Dust Bunnies" and I think there is some magnetizing of the lint. Now we vacuum the rear slots and blow out the dust as best we can.
Am curious where you bought your lamp from? You have a sleep timer on your set and it may be shutting you down when you do not change channels. The lamp can probably interfere with that like my TV interferred with the sound.
I do not know if there is a Samsung Blog, but there should be.
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
TV comes on with a good clear picture and about 30 to 40 sec goes off.
The tv projection lamp have not been replaced in this tv like the last 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours a day?Yes,than the tv projection lamp life is over.The tv projection lamp,require replacing.
Oct 18, 2010 | Samsung HL-S5087W DLP TV
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
My Samsung 60 inch DLP TV turns its self off several times an hour. Eventually is stays on. What's the problem?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.Have a bless one!
Apr 20, 2010 | Samsung Televison & Video
I have an HLR5057WAX DLP Samsung tv and my picture freezes often and the tv will sometimes power off. When it freezes it will stay that way for about a minute and usually turn back to normal. Lately I have...
The lamp is usually your first replacement, but a freeze in picture may have to do with the video board or the DMD board. Try the lamp first and see if that fixes it--because you'll need a new one anyway if you're going to keep the television. Make sure to get an OEM Philips lamp for your Sammy. Buy from an authorized distributor.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
