SOURCE: Car no longer starts
sounds like a bad battery or bad alternator.its going to be one of the two...have both checked
SOURCE: Engine won't start. Dash lights flash rapidly when key turned.
the battery says 12 volts but may be dropping to 4 or 5 under a load...i would suggest jumpstarting the car and see what happens.the battery should read in the high 12 volts and not less than 9.5 under cranking. the dash lights go out on your car when starting,and the alarm will go off ,and disable the ignition if the voltage is too low in cranking the car because the computer will shut it down and activate the anti theft.....check your battery posts are tight. best of luck
SOURCE: check engine light staying on
the light needs to be reset by someone with a scan tool which can be done for free at a local auto parts store
SOURCE: 1995 Mitsubishi Diamante is overheating. Oil
the symptoms are that you have a burnt head gasket, its consuming the water into the cylinders and at the same time it builds combustion pressure in the cooling system causing it to overheat, and when it overheats it makes the oil loose viscosity so you loose oil pressure, i recommend not driving the car any more and the first solution is to replace the burnt gasket, and change your oil, go to a local shop and only do these they probably tell you the engine is worn but the problem is what i told you above, make them replace the thermostat unit yes to be sure good luck
SOURCE: 95 honda accord turns over but wont start
Sometimes when a fuel filter is stopped up,and you change it,the fuel pump later,will go out,cause of the strain on the pump.
Testimonial: "THanks for your help!!! and thoughts.. ended up replacing distributor and now car is starting!!!"
