Is the main board bad? -
SOURCE: Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
SOURCE: no picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
SOURCE: plasma tv
you have tript the trap switch. there is one in he panel and one in the media reciever.you have to enter the technicians code followed by pressing the mute button 4 times then the display button. this should reset the trap switch.i presume you have put the cover back on. if not you must tie down the trap switch which you will see facing up
confirmation screen appears. Press [ => or
then press ENTER
This process will reset all the parameters to factory set levels. You have to adjust the Parential controls and other parameters by yourself later.
OK
