Question about Kitchen Ranges
Rayburn range too hot
Hsa control 1-6 simmer, bake and roast. When only on number 1 it is too hot and should only be at least on simmer. Help !
  • Deedee15 Nov 22, 2007
    Thanks gwshaw 71 for your reply but where in the world will I find this infinate switch
  • 83 Answers
Sounds like a bad infinate switch. Replace the switch control
Posted on Nov 22, 2007
  • Glen shaw
    Glen shaw Nov 25, 2007
    if this is one of the top burner on the range, then the infinite switch is the one you use to turn it on and off.pull the knob off and replace the rotary infinite switch.
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Frigidaire gallery electric stove too hot
You will need to replace the burner switches for the burners that are not functioning correctly.
It also sounds like you have a problem with the OCU (oven control unit), this part is known to consumers as the clock.
Do a Google search for the model number and find a supplier for the parts. All three of these parts will easily cost over $300 all together.
Also the model number you listed in missing the last 2 letters. Locate the sticker which contains your model and serial number. This sticker will be on the oven frame when you open your bottom drawer.
Apr 05, 2013 | Frigidaire Gallery GLGF389G Kitchen Range
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
Whats the difference between a slow cooker and a roaster oven?
a slow cooker just cooks slowly. a roaster oven however roasts food just like in a range oven. they can usually also bake and slow cook also. roasting cooks at a high heat while slow cookers are a lower heat for a longer time. roasters are great to use because the meat tastes really delicious and also the whole kitchen will not get boiling hot like with roasting in the oven.
Jan 24, 2013 | Kitchen Appliances - Others
When using the convection roast, does setting it to 325 show on the display as 300? I am cooking my turkey at 325 and display reads 300.
Your range has the feature called auto recipe conversion,that means it will automatically adjust your settings to compensate for the changes when useing either convection modes, bake or roast,rest assured you turkey will turn out perfect with convection roast. Remember that raosting time will be slightly reduced also with convection roast bakeing. Have a wonderfull Thanksgiving and Holiday season. Good luck !
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
233 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
