Question about Dryers
The dryer makes a loud grinding clattering noice when its on. We just moved it across the country. It was working fine before we left. The one that was here is squeaking and can run for several cycles before the clothes are finally dry. Which one would be easiest to fix? And how do you do it?
Took the back off the dryer and cleaned out a bunch of lint and metal items that had wedged themselves in around the barrel and belt.
Posted on Jul 30, 2009
    President:
  • 1,922 Answers
Try opening the door and seeing if the drum has shifted and is rubbing on the frt panel somewhere,it may have just shifted off the drum glides or bearing seat/the other one sounds as if the element is open(bad)if the other one heats fine,if both take long periods to dry clothes,ckeck for 120/240 at the main house panel and again same at dryer outlet plug-in receptacle
Posted on Jul 29, 2009
2008 Volvo S40 2.
I have seen covers or shields on catalytic converter break loose and make a lot of clatter, is it at idle only or driving ?
Aug 27, 2014 | 2008 Volvo S40
I have a mazda 6 s 2003 that make a loud humming sound wile driving but if I turn the steering wheel a little to the right it stop. if i turn left it doesnt do it but it started to make a grinding noice....
The humming might be an wheel miss-alignment. and/or
Grinding maybe the steering box (rack and pinion)?
******* ALL this could also be a worn out BALL JOINT, in which case you should have this checked out RIGHT AWAY!!!
VERY DANGEROUS to drive!!! ******
Feb 06, 2014 | Vehicle Parts & Accessories
Very loud noice coming from dryer. Sounds like belt
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 23, 2010 | GE Profile DPSB619ED Electric Dryer
Kenmore Elite HE5 front load dryer is making a loud squealling noice...Help?
heatman101
Oct 06, 2010 | Kenmore HE5 Electric Dryer
I recently moved & prior 2 moving the dryer ran fine. After the move when I hooked the dryer up & turned it on it makes a loud sound almost some kind of grinding or alarm. It then shuts itself off....
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 25, 2010 | GE Dryers
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Grinding noice
more then likely that the pump has some kind of blockage in it this will cause the washer not to empty fully which when it goes onto spin it will bang about due to the water going from side to side check the pump will be underneath just were the drain hose goes into the washer you will have to strip to get the blockage out once done it should work fine m8
Nov 27, 2007 | Hoover HW6 160M Front Load Washer / Dryer
Dryers Logo
87 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
