Question about Sony Playstation 3 (PS3) Console
Ps3 Surround sound
Ive recently bought a 60gig ps3 and am having a problem setting up the surround sound. Ive connected the hdmi cable from the ps3 to my toshiba 37WLT66 lcd tv and have connected the optical cable on the ps3 to the back of my sony av receiver but I can only set it up where I either get sound through my tv or sound through the speakers on my surround sound, how do i get sound coming out both? Any advice would be good!
  • Anonymous Aug 26, 2008
    Having problems hooking up a JVC surround sound to a Sony PS3. Using HDMI outputs and hooking up Sony PS3 to JVC and then JVC to 1080i Toshiba. Help!
  • Anonymous Feb 16, 2009
    did not help at all....bogus on both counts
I need to know how to get souround
Posted on Jul 12, 2008
It is with the setting of the PS3. HDMI is set to carry both the video and audio signals. Set the audio output of the ps3 to optical and video output to HDMI. you cannot output sound both on tv and surround speakers on the rx
Posted on Feb 28, 2008
Ttttttttttttttttttttttttttttttt
Posted on Dec 29, 2007
SOURCE:
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Want to use surround sound and use dhmi cords for picture and surround sound
You will need 2 hdmi cables the ps3 a tv with an hdmi port and a audio receiver with hdmi in and out.
1:>First connect the ps3 to the tv with the A/V cables.
2:>Turn the system on and the tv on, get to the ps3 dashboard.
3:>Under the settings tab select (display settings)
4:>Select (video output settings)
5:>Do not disconnect the A/V.
6:>Connect the hdmi cable to the ps3 and tv.
7:>Then select hdmi and select change, this gives you 30 seconds to switch the tv over to the hdmi channel. Once done and you get a signal select (yes).
8:>Disconnect the A/V cable.
9:>Select what inut your tv will support 720i, 720p, 1080i, 1080p. You can select more than one and even all if it is supported by your tv.
10:>Then select hdmi for your audio output, but since your ps3 is connected to the tv only select linear PCM 2channel. Check for sound on the tv's speakers. If check is good then proceed.
11:>Power down the tv and ps3, disconnect the hdmi cable.
12:>Connect the hdmi cable from the ps3 to the input of the audio receiver and the hdmi from the tv to the output on the receiver.
13:>Turn the ps3 on, the receiver on and the tv on. Make sure the receiver is on the right channel. If it is you will see the ps3 come on the tv, and have sound on the main speakers of the receiver and tv.
14:>At this step you should be able to see and here the ps3's dashboard. Now to setup surround.
15:>Scroll to the settings tab and select (sound settings).
16:>Select (audio output settings)
17:>Select (hdmi)
18:>Select (automatic) this will select the basic surround settings that all receivers have.
19:>Hit enter and exit.
20:>From here test the surround with a game or movie.
If for any reason you should need to restart the process, simply plug the A/V cable back in and do a video reset. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1:>Turn the system to off/standby, where only the red light is on.
2:>Then hold your finger on the front power button, it will turn on beep twice then shut back off, release finger.
3:>Then turn back on normally.
Good luck.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Surround sound for ps3 with a hdmi cable..
you need a HDMI connection for your stereo. HDMI is an all in one cable so if you don't get your sound in/out you need to hook up to just the RCA's, if you get a reciver that has an HDMI input you will solve this. then you go HDMI to Reciver then HDMI to TV
Mar 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Dec 15, 2008 | Sharp LC52SB55U LCD TV
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
729 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
