Question about Vintage Keeper 500 Plus Wine Cellar
The thermostat is set for 57F but it's staedy at
The thermostat is set for 57F but it's steady at 63F. I've vacuumed the grill and no help. Solutions or recommendations?
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
I have a 2004 Honda cbr600rr that has an irregular idle, and has hesitation in acceleration usually through 3000 rpm, sometimes higher. Everyone I've talked to seems to think that it is a vacuum leak...
If its a true vacuum leak...mapping might not help...
If you are decent as a mechanic... get some good vacuum hose and replace all of them yourself. If this doesn't help, take it to a professional(better than the last one) mechanic.
Has the bike been sitting up for a while? This would make sense for some of the issues you describe.
Try getting the carbs cleaned/set/calibrated by a pro!!
May 27, 2012 | 2004 Honda CBR 600 RR
1997 cavalier 2.2 auto, coolant leaking a steady stream, it's running to the left of the main hose that goes into the engine on the top. Is there a gasket on the block other than the head gasket??
Are you referring to the top radiator hose that goes into the thermostat housing? If so then yes you have an o-ring seal on the bottom of the thermostat housing.
Mar 03, 2012 | 1997 Chevrolet Cavalier
Smeg oven stopped working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 27, 2012 | Smeg Ovens
Having vacuum problems
check the vacuum line that goes to the fuel pressure regulator,pull the vacuum line off ,if there is fuel in the line ,the regulator has ruptured.
Jan 01, 2012 | Ford Cars & Trucks
None of my igniters on my 30400043 Ducane grill will light the burners. I've had a grease fire due to the burners rusting out and replaced the burners. The insulation on the wires to the igniters has...
As I tell customers, when they ask me, "How long will this grill last?" "That depends on well you take care of it with routine maintenance and cleaning."
The wiring for the electronic ignition and the spark ignitors are replaceable. The ignitor button or the "clicker" as you called is replaceable. But all you may to do, is change the battery inside the igniter button. To help you further, i have included a link to the Owner's Manual for your grill. It will have an exploded view of the parts, which should help you identify them by part number and order them from Ducane, if you like.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
A far as the infrared burners are concerned, they blow out easily if the wind is just blowing slightly. That's why they have a thermocouple on the burner, to turn the gas off to it, when it gets blown out. When preheating an infrared burner, the hood/lid of the grill should be closed.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Ducane 30400040 Stainless Steel Grill
I have a Honeywel T8001C. The system indicator (flame for heat) has been on for the past eight hours but no hot air is coming from the registers. Regarding this, the trouble-shooting section of the...
Is this a new tstat or has it been working? Turn power off to furnace, remove screen from stat and place the white wire in with the red. Turn power back on. If heater works the tstat is bad.
Apr 25, 2017 | Honeywell Programmable Thermostat Heater
Hotpoint FFA70P Bottom freezer not working
HI The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 07, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Vintage Keeper 500 Plus Wine Cellar Logo
46 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
