Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
When I make capuccino fine grains of cof...
By mizzdiez on Jul 28, 2009
When I make capuccino fine grains of coffee come through, spoiling the taste.
Comments:
Jul 29, 2009
- Thanks. I have checked the basket. Everything seems to be in order, no leaks. I have recently descaled, cleaned all the parts, removed old grains from around the base where the basket fits. I am using a La Pavoni manual machine, that relies on a pressure pump.
Aug 01, 2009
- I tried soaking that, thanks. Still having the problem. Doesn't make sense!Perhaps I should replace the portafilter basket thing, although it's very expensive.
Solution #1
posted on Jul 29, 2009
Somewhat Helpful)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 364 votes
Check the basket and the portafilter if you are using a manual machine, and if using a superauto check the screen in the brew unit for damage.
Comments:
Jul 30, 2009
- Remove the basket from the portafilter or soak it up to the handle in espresso machine soap(do not let the plastic handle soak in the soap just the metal part).
Aug 02, 2009
- The basket for the portafilter should not cost more than about $10. One more stupid question, since I am not able to see the machine, does it leak around the portafilter when making coffee.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
borrowed Krups 467 How to use. What is the pouch in the white holder inside brewer
Answer
Had low pressure so de-scaled machine. Now water only comes out of one of four holes in the head... (More)
Answer
this is the first time i've opened the machine out of the box. i'm trying to get it started. Yet the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
