Question about Samsung Computers & Internet
Moniter keeps blinking analog and digital at the
Just bought a new samsung moniter and it keeps blinking analog and digital at the top left corner...after a minute it just goes black and the power button light starts blinking.
    Problem Solver:
  • 11 Answers
This happens when your monitor cannot detect a VGA or Digital port, either on the monitor it self or at the video card. If you don't hook it up to anything at all and turn it on it will do this.
Step #1
First make sure that you have the cables properly connected to the monitor and to the video card using either a VGA port (blue one) or the Digital port (grey or white one). If this doesn't fix it move on to step #2.
Step #2
Try troubleshooting your video card by hooking up another monitor (if available) and see if it too is inactive. If you test with a proven functional monitor and it wont activate then you are most likely looking at a faulty video card. If your test monitor works, you may be looking at either a faulty cable or a faulty brand new monitor (it happens).
**Note: craigslist.org in the "free stuff" section is a great place to find free CRT monitors for free if you don't have one to use yourself.**
Also try to hook up your Samsung monitor to another PC (if available) to see if you get different results. If you do that and it works, that is a sign that you have a faulty video card in the first PC.
**Note: Depending on how you are trying to use your monitor (PC's only monitor, or as a secondary monitor for a PC or laptop) you may need to make sure that in your display settings you have the box checked that says "extend my windows desktop to this monitor" (Windows XP). If you are intending to use it as a secondary you will need to have this box checked or it wont be recognized.**
If you determine that the most likely cause is that your monitor or cable supplied are faulty, Samsung or your retailer should help you get a replacement. Both will ask you to verify the results of steps 1 and 2 before honoring a warranty.
I hope that this information helps. If it doesn't, post back with more information and I will try to help you find a viable solution
Good Luck!
Posted on Jul 28, 2009
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
Sep 03, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
I have a Samsung Syncmaster 2053bw. Screen
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
Jul 07, 2009 | Samsung Computers & Internet
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a emachine T6420
ohk i also have an emachine make sure you have the moniter hooked up all the way i have had the same problem
Dec 31, 2008 | E-Machines T6420 PC Desktop
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
746 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
