Question about Canon PowerShot A590 IS Digital Camera
How to open the camera bodyCanon A 590is and blow out the sand.I can not figure out how to open the top of the `cam`, the bottom screw turned
    Problem Solver:
  • 15 Answers
Try this website:
http://pkrobot.freehostia.com/MiscElectronics2.htm
It was very helpful when I took mine apart.
Best regards,
Bob
Posted on Nov 30, 2009
How do I disassemble an s4300 to clean sand from the mechanism?
Oops. Modern cameras are not made to disassemble and reassemble them. Worse, most modern cameras, can't be reassembled, because lots of things are not screwed, but glued. Opening a glued part can damage it and it is almost impossible to reassemble it without replacing some parts and glue.
Better let it dry en try to blow out (NOT IN) the sand. Almost impossible to, because when you use a bellow, it most likely will blow things in. perhaps with a soft brush you manage to get things out. sorry I can't make it easier for you.
Mar 01, 2015 | Fuji FinePix Cameras
Lenses on digital camera
yes its grain or sand only stuck in between the lens.
are you experienced in electronics for opening the camera?
Aug 10, 2008 | Nikon Coolpix 4600 Digital Camera
Hi, my Kodak easyshare MD41 will turn on but when i do it retracts the lens right away. i took it to the beach, so im guessing sand or the sand dust got in it. Is there a way i can fix this without having...
You are right it got some sand into its eyes. You know that canned Air you can get at the office supply stores I used it to blow out the sand. Remember it will blow refrigerant out if you shake it, or turn it upside down. I set it on a table so I could blow straight at it instead of down on it and I blew it off, then blew it off while I tried to open it then opend it and took out the battery to keep it open and blew it evry where i could immagine air might go and put the battery back in and :-)
Feb 20, 2011 | Kodak EasyShare One Digital Camera
I am changing the sand in my Triton filter. [filter is over 10 years old, possibly 15 years]. I have drained the water using the drain plug at the bottom. I have removed the transparent plastic dome from...
This piece screws into the elbow under it witch in turn screws into the bulkhead fitting. It will stick when removing. I will usually use the handels from my big chanellocks stuck in the holes on top of it to act as a make shift wrench to get it free, or you can turn the whole assembly sidewise a little to get under it to turn it out. After you get the sand out re assembly it and leave it off to the side to refill with sand. Be sure to have water in the filter when you put the sand in so the levels easy and dosen't stress the laterls in the bottom and crack one of them. Then rite up the assembly and feed the air bleed through the top piece. Put the lid back on and your ready to go.
Apr 28, 2010 | Pool & Spa
I need timing makrs for 1994 saturn 4cyl 1.9 dual overhead cam
They are at 12 o clock bottom and top. The bottom is easy the top you need to look at it like a clock if you aren't satisfied with that take a straight edge and align it withe the bottom mark. Make sure that on the top sprocket that the letters FRT faces you when installing and not the engine. Another thing before putting the timing cover on sand every area with 100 grit sand paper and take a screw driver and scrape out every bit of sealicon on the bottom of the oil pan. Use RTV sealant and if you sand it just enough to make a rough area...the sealant will keep any oil from seeping out and your be glad that you did that later.
Sep 28, 2009 | 1994 Saturn Sl
Dropped camera in the sand, and now it comes on and goes off
use a vacume to get any grit out. DO NOT BLOW THE CAM WITH AIR!! you will send more sand inside the unit. usually its inside the lens housing.
Jun 03, 2009 | Cameras
C913 Kodak won't turn on
check the battery where you insert on camera kodak has an error on mine <+> should be where the <-> is and<-> should be where the<+> is
Nov 26, 2008 | Kodak EasyShare C913 Digital Camera
E18 pops up
An E18 error refers to a problem with the lens. Generally you receive this error if the lens is stuck, which often happens if you drop your camera while the lens is extended or if something like sand or dirt gets inside the lens barrel/gears. Your situation, however, sounds different since the lens seems to extend before giving the E18 error.
If the lens is fully extending before giving the E18 error, you most likely have a problem with the lens sensor located around the O-ring inside your lens barrel... either the sensor itself is damaged or the little plastic piece on the O-Ring that triggers the sensor is broken. If that's the case, there is nothing you can do yourself unless you feel like taking apart the entire camera and finding a replacement piece.
If the lens only comes out a little bit and is not fully extending before giving the E18 error, it sounds like something is making your lens get stuck. If you've recently been to the beach or a park where there is sand, try using a can of compressed air and blow it into the little gaps in the lens barrel... you may be able to blow the sand/dirt out, solving your problem. If the air doesn't work and you feel comfortable taking apart your camera, you can get to the gearbox and manually retract the lens by following my instructions below. Otherwise, I'd suggest a repair shop.
WARNING: TAKING APART YOUR CAMERA VOIDS THE WARRANTY AND CAN BE DANGEROUS! The capacitor that charges the flash can still hold enough voltage to give you a massive shock even when the battery has been removed for some time. Please only attempt to disassemble the camera if you feel comfortable doing so. I accept no liability for anything that happens should you follow my instructions below.
In order to open the camera you will need to remove six screws on the outer casing (2 where the wriststrap ties on, 2 on the opposite side, and 2 on the bottom). After unscrewing all 6 screws, pull the back and front casings off from the bottom out, as there is a clip-hinge on the top next to the shutter button that needs to disengage before you can fully remove the casing. Once the casing is removed, there is one screw holding in the flash apparatus, on the side. Remove it and carefully bend back the metal cage around the flash apparatus and pull it up. The flash will still be attached to the camera with a pair of wires (yellow and black) and a ribbon cable... leave those in place. Please be CAREFUL when handling the flash because the capacitor (the big black thing under the flash) can hold enough voltage to give you a severe shock even with the battery removed. Underneath where the flash was you will see a multi-tiered black piece of plastic... this is the gearbox cover. Remove the three screws from the cover and carefully lift the cover off the gearbox. Inside will be a motor shaft and 4 gears (2 white, 2 black). Remove the BIG black gear closest to the lens. Then temporarily replace the gearbox cover. With the big black gear removed, the lens should freely glide in and out if you push or pull on it. Do this several times in order to clean out any gunk that may have gotten into the grooves of the lens barrel. Then, open up the gearbox, replace the black gear, and screw the gearbox cover back on. Replace the flash into the metal cage and screw it back in. Finally, put the metal outer casing back on the camera and, before screwing it in, try to turn it on. Hopefully it will work again and you can screw everything back in. If not, your problem will require significantly more disassembly.
Apr 02, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
My Lumix won't stick it's lens out.
I recently had this problem after a trip to a sandy beach. The solution was to take the camera apart and blow out all the sand and dust. To help you get it apart, take off all the obvious outside screws and then unhinge the back and front, with the hinge point being the top. The back and screen can easily be removed by tugging on the cables where they fix into the circuit board. (Just push the large cable back in, for the smaller cable you need to use the little hinge on it (initially put the hinge towards the edge of the camera, insert the small cable, then fold the hinge back towards the centre of the camera. Continue to take out small silver coloured screws with a jeweler's screwdriver. I was able to get to the elecromechanical optical train in this way. I did not have to remove the tiny black screws inside this unit. After thorough cleaning and blowing out dust/ sand etc. the camera was fairly easy to put back together. Total time was about 90 minutes. Note: there was no need to take off any of the buttons on the top, nor to take out the battery nor memory card. Good luck.
Mar 31, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
98 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
