Question about Linksys WRT54G-TM Wireless Router
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share problem? 2 dual-core computers both XP v3 plus laptop vista64.
  • 404 Answers
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Posted on Aug 02, 2009
Hi im trying to connect my new wireless router netgear mod.dg834g v5 with virgin supplier.should it not be a simple connection from the existing modem into the n/gear or i didnt get a internet conn.so use...
Ya this is some what correct. You might be lacking on some system network setting. Just you have to do is make sharing of your network without any complecated authorised or password sharing. Thats it.
May 31, 2010 | NetGear DG834G Router
Can the HP PSC 2410 printer be shared between 2 computers?
generally the printers with single USB port are dedicated for use with one computer.
However, depending on the way you connect the computers you can share the printer with more than one computer.
1. SET THE SECOND COMPUTER UP AS A NETWORK PRINTER
This is one of the most common ways to connect two home computers to the same printer. The advantage of this technique is that it doesn't cost you anything extra. You do require some computer literacy in networking though.
Firstly you physically connect the first computer to the printer via the provided cables. The second computer now needs to be set up as a network printer to have printing capabilities. The computer not physically hooked up sends a message via the network to the computer which is physically connected to print.
To set up the network connection in Windows follow these steps:
-Open the control panel
-Select the network or network and sharing icon
-You should see an icon named file and print sharing or simply print sharing. Turn on printer sharing if it is off.
(This requires your two computers to already share a network connection; otherwise you will have to set this up).
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/print_sharingw.mspx?mfr=true
2. PURCHASE A PRINTER SWITCH
A simple old fashioned way to connect two computers to one printer is by hooking them up to one switchbox in the middle. This switch is what is connected to the printer. This is a similar method to using a router to distribute the Internet to more then one computer.
This method is good for people who aren't very computer literate when it comes to networking. All you have to do is plug the cables in and off you go. However, it has one large disadvantage which is that the computers and printer all have to be in close proximity for the cables to reach.
The printer server should support the printer so that you can get maximum functionality from the printer device (including the multifunction feature).
http://cgi.ebay.com.au/Gray-Steel-Two-Ports-Printer-Sharing-USB-Switch-Box-/180502082365?cmd=ViewItem&pt=AU_Computers_Printer_Accessories&hash=item2a06c3333d
3. You can buy a printer server but for that you need to make sure the device fully supports the printer you have got including the multifunction features. Both computers will need to have network connection.
Something like http://www.netgear.com.au/au/Product/Print-Servers/Wired-Print-Servers/PS121
or
http://www.belkin.com/IWCatProductPage.process?Product_Id=354892
May 07, 2010 | HP PSC 2410 All-In-One InkJet Printer
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I what to share my printer with the other laptops in my home.
you can share the printer in your desktop.( lets call it computer A ) . When you want to print from computer B, go to Start - Run - type in \\ computer A or its IP address and print from there.
Thanks
Ranjit ranjit@supportminds.com
Aug 06, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear FS105 Switch is not fowarding ports properly.
Does your modem have a built in router or do you have a router in your network. The switch needs no changes that's all it is a switch it will allow computers to talk and share fine, if you want to use it for internet you will need to connect it to a router first or use one of your computers as the router and let it share the connection. since you disabled DHCP on your router I am assuming you have a router. all you need is to connect the switch to the router, the connect the computers to the switch and all should work.
Dec 24, 2007 | NetGear FS105 5x10/100 Mbps Networking...
Belkin wireless router
You may contact to belkin tech support and ask for assistance. hope they will help you to resolve your problem. for more information you may visit : Belkin Tech Support Helpline For Router 1800 585 2494
Nov 11, 2007 | Belkin (F5D7230-4) Router (587009)
Wireless printing
Hi, Through what method would you connect the printer to the netgear? I have looked at the information on both products and the netgear has no Print Server and the Printer has no Ethernet or wireless. If your printer has no ethernet or wireless and your router has no print server then the answer to your question is NO. HOWEVER: You can install the printer on any one of the pc's and then set it up as a SHARED PRINTER. If you would like further information on doing this please let me know and I will post it here. Thanks
Aug 21, 2007 | NetGear WGT624 Wireless Router
Linksys WRT54G-TM Wireless Router Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
