I have a Dell monitor- about 7 years old. the contrast adjustment screen appears all the time. Sometimes I push the button on the monitor and it disappears for a short time then reappears . How do I get rid of it.
Sounds to me to be either a failing button position replacement spring in the button itself. This problem also could be caused by dirt buildup surrounding the hole in the monitor bezel where the button protrudes. Try using a dental tool or something small and pointed to clear any possible debris from the buttons edges. Also some canned air may help. If these things don't fix your problem the bezel may need to be removed for a more thorough cleaning. If you are able to make it dissapear by pressing the button it most likely isn't hardware failure causing your problem, as those buttons are rarely used.
I unlocked OSD Locked of CRT View Sonic Colour Monitor desk top ( Block) by pressing. while restart...
(More)
I unlocked OSD Locked of CRT View Sonic Colour Monitor desk top ( Block) by pressing. while restart every time it appears on screen OSD unlock blue colour menu. How to resolve it. please help.
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt...
(More)
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt get any signal
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no...
(More)
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no matter where I go, or on line. It does change colors to what ever I was doing last. Do you have any idea how to git rid of this? Thanks
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2...
(More)
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2 solve this problem pls help me....thank you
