Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Water not squirting - Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
    Problem Solver:
  • 9 Answers
Check the belts, if the belts are good then the heater block is clogged, it is common i get 2-3 a week with the same problem. Good luck!
Posted on Jul 28, 2009
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
I love my floor cleaner n I would be lost without it. I use it once if not twice a week. But...when I went 2 use it this week it will not squirt the water out when I pull the trigger so I used a squirt...
Check that the bung that closes off the water outlet hole is not stuck in the outlet. Remove the water container and check the underside where the outlet is while operating the opening mechanism.
Jan 16, 2011 | Hoover H3030 FloorMate SpinScrub 500...
My bissell worked well cleaning my carpets it's only 1 year old when i stop'd it to refill water it would turn on put not spray what can ido to fix this problem
TAKE OFF THE CLEAN WATER TUB IF IT COMES OFF TO FILL AND LOOK FOR SCREENS OR FILTERS THAT COULD BE PLUGGED OR AT LEAST LOOK FOR THE LINE THAT CARRYS THE WATER TO THE PUMP AND AGAIN CHECK FOR LIKE HARD SOAP AND STICK LIKE A NEEDLE IN IT BUT CARFUL NOT PUNCTURE ANY TUBES THE WORST CASE IS THAT THE PUMP THAT MAKES THE WATER SQUIRT OUT IS BAD SAME AS IT BE IF YOURE CAR STOPPED HAVING WINDOW WASHER FLUID SQUIRT OUT
Jan 19, 2010 | Vacuums
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Dirt Devil Featherlite carpet shampooer won't release solution
Had the same problem only after 2 uses, called the 1 800# said that soap may have "gummed" up the line did everything they said but didn't work. Would cost more in service repair if I could find a authorized dealer to fix than I paid for the machine. Would not recommend this machine to anyone.
Jun 10, 2009 | Dirt Devil CE6100 Featherlite Upright...
Model 1400 little green cleaner does not squirt fluid
its just the prime.if all the water is let out of the hoses it will need to be reprimed with water again.once water fills the hoses it will work fine
Dec 10, 2008 | Bissell 1400 Little Green Pro Canister...
No water spraying
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Aug 10, 2008 | Bissell Vacuums
Bissel pro heat turbo. I beleive it is clogged with ahir and fiber. i don't see water going up through the front How do I unclog
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad.
Apr 24, 2008 | Vacuums
Bissell water not working
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Oct 21, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water
That red thing is most likely the float asm Part #2140325 .
Oct 17, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
376 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
