Question about Samsung Eternity Cell Phone
While talking on my samsung eternity, it will just shut down, but comes right back up. why does it do that?
Samsung eternity change apn
Eternity 2 settings for straight talk
i finally figured it out.
in fact the browser does use the same profile as mms on straight talk. but there are 3
settings for this phone in which need to be changed in order to use internet and mms..
I just found this been looking all day. i havn't got to try it yet but seen several people post they did it and everything is working. good luck.
1st is application/messaging/multimedia message/mms profiles/select the st profile added....
2nd is application settings/browser/browser profiles/select st profile added.....
3rd that i was not aware of....applications/more/connections/default/select st profile added....
everything seems to be working correctly now
Jun 30, 2012 | Samsung Eternity Cell Phone
Samsung Eternity does not text. the screen comes
Try to re-install the software. If that doesn't help you have to call the Samaung service provider.
Jul 23, 2010 | Samsung Eternity Cell Phone
Why does my Samsung Eternity A867 constantly shut down then restart itself whenever I am on a call or just answering a call? This has been going on for too long.
technical malfunction, make sure the battery is in nice and tight and dont bounce the phone off your hand or anything that could knock the bettery loose
Jul 21, 2010 | Samsung Eternity Cell Phone
My samsung a867 restarts I can do and when I connect to the computer does not see
As mentioned, the front of the Samsung SGH-a867 Eternity is mostly covered by the large 3.2" touchscreen display. There are, however, three buttons along the bottom edge of the phone, providing send, end, and back functions. The 'End' key pulls double duty as the power button, so you can easily turn the phone on and off. On the top edge of the Eternity, there is a single 'Hold' button, used to quickly lock the touchscreen from accidental keypresses. Along the right edge of the phone, towards the top, is the standard 3.5mm audio port, which is definitely a welcome feature. Below this is the application switcher button, and below that, the dedicated camera key.
The microphone is located along the bottom edge of the Samsung Eternity, and along the left edge is the proprietary power/data/headset multi-jack. Also, the volume rocker is located towards the top of the left edge. The 3 megapixel camera is located on the back of the Eternity, and the entire back panel slides down and out to offer access to the battery and SIM card slot. There is a microSD slot, though it is frustratingly located behind the back panel and requires removal of the battery to change the card.
Jun 19, 2010 | Samsung Eternity Cell Phone
My samsung eternity wont let me hear ppl who r talking to me on a call and i cant hear them on a call
This is a device issue. You will need to contact your service provider for replacement options!
Mar 06, 2010 | Samsung Eternity Cell Phone
Samsung Eternity- Can you set a picture for the "lock" screen?
sorry, there is no way to change that yet..... maybe someone will come up with a back door but i doubt it
Aug 24, 2009 | Samsung Eternity Cell Phone
Freezing when I install a micro sd card into my samsung eternity
i had the same problem. so i try whatever i can
- i remove battery, put it back on, turn the phone back on. seems like it works for 3-5 minutes and freeze again
- i remove sim (only ),memory card still in there, and turn the phone back on..let it sit with no sim. and 3 minutes later it freeze again
- i remove sim, remove micro sdhc, reset the phone , the phone automatic restart..it woks... it never freeze ( no sim+ no memory card )
- i put the sim back on, no memory card, turn the phone back on and it works!!!!!!! i try these 2-3 times without memory card. works normal!!!
so..i think its a memory card issue. may be the phone doesn't like it. i have 2gb. kingston. or i have to buy a new card again.
for now its still working without freeze up for shut down by itself.
hope it help :)
moo
Jul 16, 2009 | Samsung Eternity Cell Phone
Samsung eternity wont play back sound
I had a problem similar to this a few times and found that it was due to the phone thinking that there was still something in the headphone jack so the only sound that would come from the phone was a ringtone or when using the speakerphone. To fix it you can plug in and unplug your headphones (while playing music) until the external sound playback comes back. Hope this helps!
Jun 08, 2009 | Samsung Eternity Cell Phone
Samsung Eternity SGH-A867 network locked and now phone freezed
somebody typed invalid unlock code too many times. Now you need to unfreeze your phone with special unfreeze code. Only way to get this code is to read it via USB cable. There is no free solution to get unfreeze code :(.
You can purchase it at http://www.fastgsm.com/en/samsung/samsung/samsung-a867-eternity/unlock-code
Jun 03, 2009 | Samsung SGH-D500 Cellular Phone
Samsung Eternity  Cell Phone Logo
90 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
