Question about Refrigerators
My refrigerator will not get cold, but the freezer work fine.
  • 2 more comments
  • b1jqxk44
    b1jqxk44 Oct 17, 2017
    If the fan is working then the vent tube from the freezer too the fridge is plugged. The vent tube is located in the middle bottom of the freezer and the middle top of the fridge, unplug that tube with a stiff wire.
  • b1jqxk44
    Take everything out of the freezer and take the bottom plastic piece out to get at the tube. Same in the fridge now you can unplug that tube.
  • b1jqxk44
    If it's iced up unplug the fridge and let it melt.
  • Asif Naveed
    Asif Naveed Nov 28, 2017
    May gas re-filling needed.
    also clean the condenser may be dirty.
  • Refrigerators Master
  • 1,769 Answers
Are fans running? Any frost on inside back wall of freezer? Model #?
Posted on Sep 14, 2017
    Top Expert:
  • 50,174 Answers
Call a repair service
    Master:
  • 466 Answers
I would pull it out from wall..Check to see if the fans running...Unplug and get all the dust out. Put a little clearance between the wall and back of frig.Check the thermostate. Sometimes people shove food across it and change the settings. Also as you open your door hold the button down with your finger and the fan will cut on with the door open to check it
Posted on Nov 28, 2017
fridgetech
  • 473 Answers
SOURCE: My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Posted on Oct 21, 2007
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
SOURCE: THE FREEZER IS WORKING BUT NOT THE REFRIGERATOR
your defrost system is malfunctioning un plug refrigerator for about 2 hours replug and check if it makes a difference check if fan in freezer is working , you may need atechnician .
Posted on Mar 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
  • 24 Answers
SOURCE: Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Posted on Jul 28, 2009
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
The refrigerator isn't getting cold
the refrigerator part isn't getting cold. it was working but now its just room temperature inside. the freezer part works fine.
Jul 03, 2009 | Whirlpool Refrigerators
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Refrigerators Logo
2,275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
