Question about Ricoh Office Equipment & Supplies
Ricoh Irregular Toner error message Toner levels appear OK, reseated the cartridges, but same error.
  • Ricoh Master
  • 10,314 Answers
Take the toner cartridge out and shake it vigorously. The toner level inside may be getting low so shaking it distributes what's left.
Posted on Sep 14, 2017
Testimonial: "The ink gives the same message and it is a full lass"
SOURCE: error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Posted on Nov 23, 2006
SOURCE: OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Posted on Sep 16, 2007
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
  • 8 Answers
SOURCE: Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Posted on Oct 29, 2008
SOURCE: Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Posted on Aug 17, 2009
How can i fix the 'replace toner cartradge 'which is show in ricoh printer 4210
Please follow the steps to replace the toner cartridge on the attached link: http://support.ricoh.com/bb_v1oi/pub_e/oi_view/0001037/0001037078/view/hardware/unv/0084.htm
http://www-it.desy.de/systems/services/printing/help/Manuals/Ricoh/SP-4210/Manual/hardware/unv/0098.htm?lang=en;view=print
If the message Replace Print Cartridge remains, it means that it is not the correct toner cartridge, replace it with the correct one. If Reset Print Cartridge message appears after correct replacement, it means that the toner cartridge is not set correctly or not installed. Set the toner cartridge correctly. If the cartridge is installed, close the front cover and turn the power switch to off and to on. If the message appears again, contact your sales or service representative.
Apr 17, 2017 | Ricoh Office Equipment & Supplies
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
Add toner see instructions in front cover to replace toner
Hi
You say you have checked the toner and there is "enough inside", I don't know how you can check this and the error suggests that the cartridge needs replacing. Have you tried a new cartridge ? This is the first step.
Is the cartridge you get the error with a Ricoh cartridge or a compatible. If compatible this could be the cause of your error.
Cheers
Dec 06, 2014 | Ricoh Aficio mp2000 Copier Machine
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
Feb 15, 2011 | Lexmark C534dn Laser Printer
How to do a printer cartridge reset on SP4210N AFICIO PRINTER
Jan 17, 2011 | Select Products Aficio SP4210N Laser...
Error code 14 "no tuner cart"
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
May 06, 2009 | HP LaserJet 4 plus Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
2,238 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
