Question about Epson Stylus CX6000 All-In-One InkJet Printer
EPSON STYLUS DX6000
E-90 ERROR
  • 3 more comments
  • Mattel Nov 24, 2007
    hello, i have an error for the epson cx6000 with an e-90 message as well. does this mean i need more ink? it wont let me do anything including scanning, so i was wondering if it is a problem other than ink. thanks
  • Anonymous Dec 02, 2007
    my DX6000, after changing the yellow ink ctg, started a grinding or slipping of gears then the E-90 contact Epson screen appeared on the LCD.
    I checked the lid to the unit and made sure all ink caridges were set and locked into place.The startup of the printer after reset the print caridge moves back and forth freely then settles down in the cradle on the right. The yellow carrage movement belt then vibrates as if it is moving or slipping over the (sprocket) gears.
    stewartad3@hotmail.com
  • Anonymous May 29, 2008
    I HAVE TRIED SO MANY TIMES TO START,INSTALLING NEW CARTRIDGES PLUS SWITCHING ON AND OFF BUT NO LUCK
  • cheriemor Jun 13, 2008
    my stylus seems to be ok when i turn it on the head moves back and forth freely it then settles in the rite hand corner and e-90 appears on the screen along with 3 little cogs any 1 help me please
  • DONJULY May 11, 2010
    What`s means "E-90 " message and how I can resolve that problem
To correct my E-90 error I opened the lid and saw that there was a torn piece of paper under the carriage which jammed the carriage so it could not move. Two minutes later, after I moved the carriage by hand and removed the paper jam, I powered off and back on and I'm back in operation. Thanks to all before me who suggested it might be user fixable.
Posted on May 25, 2008
Found a big piece of plastic stuck in the paper inlet. Removed it (damn kids) and it worked. No new drivers or utilities required. Just find the foreign object in your printer. By reading some of the other posts, this could even be something fallen inside the interior....
Posted on Nov 13, 2008
OK - so I had the same problem and was ready to toss it. but instead while in the error mode, I opened the hood and released the ink jet carriage and slid it to the left. Then you can see/fell numerous mecnanism on the right interioer bottom made of plastic and that move up/down/back/forth. I fiddled with these hoping they were out of alignment or something missed a grove or didn't actuate
Sure enough, the printer reset, realigned itself and not works.
Posted on Apr 24, 2008
  • Epson Master
  • 1,879 Answers
An E-90 error is a fatal error with the printer itself, the only solution is to contact Epson if the unit is still under warranty. I understand the fix is more costly than the printer ( check this link http://www.epson.com/loyalty ).
The error seems to be reported most when a new cart is installed, you could try reseating the cart, powering down the unit for 15 min and then plugging back in and see if that will reset the printer.
Posted on Jan 04, 2008
I got the same error after not using my printer for a about 2 weeks, so i opened up the hood and sure enough i found a glue stick (how'd that get there?) inside of my printer all the way on the left where i could barely see it. powered it back up and i was back in service!
Posted on Oct 02, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Hey Guys, I had the same problem and I just got it fixed in less than 3 minutes.
1.Unplug the power cord and the usb cable then carefully take take the printer and turn in upside down and shake it gently, I found in mine 2 coders a nikel and a big coat button(funny I know...)
Also inspect visually for some other things who inadvertenly got inside your printer.
Posted on Dec 12, 2008
Mine is doing the same thing, but I soaked some (a LOT) of ink from the reservoir and it worked again -- ONCE. Then it powered off again and won't come back on.
Posted on Jun 24, 2008
I guys my cx6600 just wont turn on and yes i have change the fuse
Posted on Sep 22, 2011
SOURCE: Epson Stylus DX6000
E-90
Posted on Dec 09, 2007
Basti
  • 1447 Answers
E-90 error is an indication of an internal problem on the printer itself. The only thing that you can check/do is to power cycle( turn it off and unplug from power supply) the printer and check for obstruction inside and press on the cartridge cover on the right hand side of the printer but do not manually move printhead to position where you can take the cartridges out it will damage the printhead. then replug and turn it back on. if you get the same error, check for date of purchase if its still within warranty call epson for replacement and a set of ink will be included with it. Hope that helps.
Posted on Apr 14, 2008
rioglen
  • 95 Answers
SOURCE: Epson Stylus DX6000 only printing half pages
try to perform a cleaning cycle, if your running on windows just go to the control panel look for printers and faxes, find your printer icon then right click once left click on printing preferences, left click on the maintenance tab then click on head cleaning for about 3 to 4 times in a row. then check for a test print and see if it still persist.
Posted on Sep 14, 2009
cene765
  • 787 Answers
SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Posted on Oct 16, 2009
Basti
  • 1447 Answers
SOURCE: epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Posted on Oct 14, 2010
Testimonial: "Thanks, thats wot i thought. cheers"
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Scanner error
Press the On button to turn off the Stylus Photo RX500. Unlock the transportation lock. Make sure that all packaging materials have been removed. Turn on your Stylus Photo RX500 again. If the error message still appears, call Epson so they can replace your printer.
Goodluck.
sherlyn C.
May 23, 2009 | Epson Stylus Photo RX500 Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson stylus photo 895 error code
1Eb means no black ink, 1Ec means no colour. Change the cartridges and you should be good. you will need Epson cart numbers: T007 Black T008 Colour
Sep 28, 2007 | Epson Stylus Photo 895 InkJet Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
7,338 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
