Question about Kodak Office Equipment & Supplies
Kodak i1420 scanner won't scan duplex mode. When
Kodak i1420 scanner won't scan duplex mode. When I set my software to :"feeder" it scans just fine (one side) but when I set it to "duplex" the scanner just sits there and doesn't attempt to even feed the document.
3 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Scanner problem
Try scanning a double sided document in duplex mode. Reverse the page and scan again. Make sure contrast/rightness settings are okay. If one side output is still not okay, then it possible that the lighting has failed. Either loose contact or failure of the lamp. Some scanners have LEDs and some have a lamp.
S. Mohan
Posted on Feb 21, 2008
I contacted tech support at UMAX
Posted on Apr 24, 2008
Operation error when scanning
Ensure you have the most up-to-date drivers for your i1420: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Departmental/i1420_Scanner/Support/Drivers_And_Downloads/i1400_Series_Scanner_Drivers/index.htm Looks like v3.09 is the most recent. If you are unsure of your version, download and install v3.09, if your drivers are out of date, the install will update your drivers. Test the scanner using the Scan Validation Tool (SVT). This program should be located in the Kodak folder in your start menu. SVT will test the scanner's functionality at a basic level alleviating all third party software variables. Please consult your owner's manual if you are unsure how to initiate a scan in SVT. If the 1420 scans perfectly then you need to contact IRIS for support: http://www.irislink.com/c2-2365-189/IRISPowerscan---High-Speed-Scanning-Software.aspx
Mar 24, 2014 | Kodak i1420 Pass-Through Scanner
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Good afternoon. I need help. We have a KODAK i1420
If the software driver is loaded (it must be otherwise you will get e red light ) check the Image guides (the plastic window strips) check the whit reference on the underside of the guides is in place and in good condition
Oct 24, 2013 | Kodak i1420 Pass-Through Scanner
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Hi
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
Can i get front and back side of pages scanned at a time, if yes then how? how can i scan a book of 50 pages by giving one command?
What scanning software are you using? In Adobe Acrobat Professional 9, you can set up different scan profiles, including duplex scanning. The sheet feeder holds up to 50 pages; you just tell the software to make all pages one pdf.
Dec 02, 2010 | Kodak i1220 Pass-Through Scanner
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
No duplex scanning
Try going to the hp solution center
Then settings, scan settings, scan preferences (third from top), under the automatic tab, bottom of list is “Scan both sides of the original when using duplex feeder”
I’m using version 70.0.128.000 of the HP Solution Center if that helps.
I told my brother once to ask HP support about a problem for his laptop, and they proceeded to instruct him how to make the problem worse and royally screw up stuff that was completely unrelated to his problem.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Scanner problem
Apr 23, 2008 | Umax Astra 2100U Flatbed Scanner
Duplex Scanning
I havent used WYNN wizard. I use Capture perfect ver 2.0 it is available free of cost. Try with it. If it is okay, then may be some setting is missing. If it remains same, then there be some hardware issue in the scanner.
S. Mohan
Apr 16, 2008 | Canon DR-7580
Scanner problem
S. Mohan
Feb 19, 2008 | Office Equipment & Supplies
163 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
