Question about GE GSD5620DBB Dishwasher
Sig amount of water remains at the bottom after a wash
    President:
  • 704 Answers
First check that there isn't anything blocking the drain area inside the bottom of the dishwasher. Sometimes plastic wrap, a small Tupperware, etc. top gets sucked against the drain and blocks discharge. If nothing is there, (look really good, by getting out as much water as possible!!!). If nothing there, see if you have an "air-break" installed at the kitchen sink, this prevents backflow from the sink drain back into the dishwasher, check it by removing the decorative cover and see if it is clean and has no obstructions blocking water flow.
Another thing to check, is if you recently had a new disposal installed, it's possible that the dishwasher inlet was never "punched out" all the way to allow for the dishwasher to properly drain thru the disposal. If none of those, continue with the investigation!
Check to see if some broken glass might have worked its' way into the drain area, beneath the drain discharge guard. You'll have to remove the cover, some are just clipped in place while others have a screw holding them in place.
If still nothing, it is possible that something has worked its' way all the way into the discharge pump section and you'll need to remove the dishwasher from under the counter to get at the pump section.
Normally when the dishwasher is in the pump out sequence, you can hear the pump motor and impeller spinning. It is possible that you have a partial obstruction and will have to remove the pump housing to get at the problem
Bucket and towels will be needed to soak up all any water that you couldn't remove before pulling the dishwasher out from under the countertop.
If there is no obstruction in the discharge pump section check the discharge value (usually a simple rubber flap) is moving freely and has nothing obstructing it.
You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working OK again.
Posted on Jul 28, 2009
Dishwasher (Kleenmaid DW361) not draining properly at the end of the cycle. Just a small amount of water remains in the bottom.
How much is a small amount? I presume this is something new, since a little water always remains to protect the lower seal.
Otherwise, use a flashlight to look into the sink drain and ensure there is strong flow from the DW when it is pumping out water. If not, there may be an obstruction in the discharge line.
On some units (my Samsung??) there is a float chamber on the side (entire unit must be pulled from enclosure) that gets clogged and discombobulates (technical term??) the water level reading, allowing water to remain in the tub. Cleaning required!
Debris may also accumulate under the cover on the bottom of the tub which effects proper draining. Fasteners are usually obvious and you may be surprised at the mess.
Be careful to note positions of all gaskets and screws!
Oct 25, 2016 | Dishwashers
Is it normal to have substantial amount water remaining in the washer after final spin?
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
Jul 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
It has a horrible odor. Also the little door on the left bottom front of the machine holds water. How do you keep the water (stinking) from standing in that area?
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
If the standing water is your fabric softener you'll have to clean it out to unstop it so it will drain.
Here's a DIAGRAM which may help with the cleaning.
Mar 12, 2011 | LG WM2233H Front Load Stacked Washer /...
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Water left in compartment
You need to elevate your dishwasher drain hose under the sink. The water going down your disposal side is running down the hose into the dishwasher.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Front loader
something is restricting the draining of unit either in the drain hose, but most likely in the pump remove the bottom panel and pump is in the middle and have 2 5 gal bucket handy to catch the water when you unscrew the cap to the pump ----- unless you use your wet/dry vac to empty the tub this is the best method then only a small amount of water will remain
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Clothes remain dripping wet after the wash cycle is complete.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
GE GSD5620DBB Dishwasher Logo
134 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
