Question about Minolta bizhub 350 Black and White Copier
Color looks blauchy. all consumables are at a good level. what I should?
  • Minolta Master
  • 6,680 Answers
Sir is this a C350 or a straight BZHUB 350 B &W. If it is a color have you toned up the machine and ran gradation stabilization? Check the half tone prints of each color also if C350
Posted on Apr 06, 2010
  • 313 Answers
Check the fuser rollers for wear also lift the lid and look at the mirrors on the scanner unit to see if there is and dust on them as this affects the copy quality if you are using for printing check the difference in quality if the prints are better the problem is in the glass copy area could be dust or paper dust on mirrors.. if not the drums or transfer could be worn have you had it serviced if not that may be required
Posted on Jul 31, 2009
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Motorola s9 battery dead how to replace it. for replacement is there it is just use and throw one only? please let me know
After googling the problem, I saw a couple of PDF documents that said that Motorola would replace or change the battery, but the links to the documents were outdated. At this site, they said the battery is non-replaceable: http://direct.motorola.com/ens/s9/Headset_Home.asp.
I found this site for support, and it looks like it might be worth a try:
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=26428dda028e0210VgnVCM1000008406b00aRCRD
It looks to me like the battery can be replaced, at the service level, but that normally it is a throwaway item at the consumer level. See if they can help you, but, of course, get the price first, and that will tell you whether to have it fixed or replaced. Good luck, and hope this helps.
May 25, 2010 | Motorola Mobility S9 Headphones
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
Hp 4050 does not print gray
Please try to edit the setting of your printer particularly the printing level of your printer such as the ink it consumes and the color of the ink you are going to used. So if you want to have a good quality result then please select the best quality printing it can give of your printer by editing the printer setting.
Thanks
Aug 18, 2009 | Office Equipment & Supplies
42" sony plasma wont power on
I don't think Sony makes a Wega Plasma. Sony did make a plasma about 7 years ago but it wasn't Wega. Are you sure it's not Grand Wega SXRD or Lcd type
Apr 13, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Oil level for Suzuki TS 185 (1989)
Drain the oil and put 750ml back into the gearbox. If your bike doesn't have a dipstick and you have good, clean oil in it, drain it into a plastic bowl then put it right back into the engine but measure it before you pour it back in. When you get 750ml in the box then look at the level in the box. That is the level to maintain.
Pleas rate this solution. Thanks!
Mar 29, 2009 | 1981 Suzuki TS 185
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
Color toner
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
Nov 04, 2008 | Canon imageRUNNER 210S Copier
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Minolta bizhub 350 Black and White Copier Logo
97 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
