Question about Goldstar GW-HD5000 Window Air Conditioner
Unit overheating and blowing fuses
GOLDSTAR MODEL GP 100 CE PORTABLE AIRCONDITIONER
My unit was running fine but now it seems to be overheating and blowing the fuses. What could be the problem?
Thanks,
    Problem Solver:
  • 13 Answers
Low gas pressur causing the unit to overwork/heat, water trap coolant service port blocked. Some machines need 1/2 liter of water pouerd into a reservoir on the rear to aid cooling the heat exchanger, if this is dry it will overheat. cheakc the filters if it has any.
Posted on Jul 28, 2009
Does goldstar still make parts for the GoldStar R5000 particularly the fans
It depends on which parts you're looking for. Some are interchangeable from other Goldstar units.
Here is a link to where you can probably find what you need..
http://www.appliancefactoryparts.com/airconditioners/goldstar/
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Goldstar Heating & Cooling
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
We have a Goldstar portable AC. It runs fine but
Refrigerant leak.....not worth fixing.. will cost more then a new one...
Here is a tip for other things you can check first....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 27, 2010 | Heating & Cooling
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Jul 05, 2010 | Goldstar KG6000R Window Air Conditioner
A/C not blowing cold air (posted on 1995 maxima forum in error)
check for system leacks (lines,fittingis,comperssor,dryer,condensor )
Jun 23, 2009 | 2002 Nissan Maxima
2002 Nissan Maxima SE - Air condition not blowing cold air
simply "adding a can"is a good way to end up with non-functional A/C. the typical system has high/low pressure switches that enable/disable the system. you need to be at the correct volume of refrigerant as specified on the sticker under the hood. i recommend using the proper equipment, evacuating, pulling a vacuum, and then refilling the system with the appropriate amount.
Jun 23, 2009 | 1995 Nissan Maxima
I have a Continental Portable airconditioning unit that I have to drain every couple of hours?
your problem is that u need a general cleaning ,an with out that u will still have that problem.Now if you have a little knowledge on how to open the system thats somthing u could do yourself..Once u get the system open locate the drain assembly ,make sure that pan an hose both are cleaned out an while you are there go ahead an clean the coils on the unit to prevent any head pressure an that the unit supplies air properly if you dont have any drain cleaner for your unit use ,bleach just a little cap full an pour in pan..an after you get it clean.once a year pour in drain hose ..That should take care of your problem
Aug 15, 2008 | Continental CE-PAC1062 Air Conditioner
Goldstar Window A/C Unit Model GWHD5000
I recommend that if you have animal and you want to have the unit on all day that is fine if you have an ac unit with a thermostat and it is big enough to handle.  The unit that is in the window is ok if your home but it could cost alot if there is no thermostat because it will run and run and run.  Then if it don't cool the house enough means its not the right size.  The unit / compressor could overload and kick on and off and might not work when you get home and the house will be like a firecracker.   Best bet would be to replace it with a unit for the size needed for the apartment.  It would be effecient. if we can help further just let us know.
Jul 15, 2008 | LG Goldstar GWHD5000 wall/window Air...
Heating & Cooling Logo
515 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
