Question about Sharp UX B20 Plain Paper Inkjet Fax
I have sharp UX-B20 and when i print there are horizontal gaps. I have cleaned the nozzles many times but it has not improved
Change the cartridge, BUT never-never use refilled or re-manufactured one! Original ONLY! UX-C70B
Posted on Jan 07, 2010
Everything is setup properly and the printer actually attempts to print, but nothing is showing on the paper---the ink carts are full, but I have not used printer in a year
It could be that the nozzles on your cartridges have clogged due to long period of non-usage. Try to follow the steps below to clean the print cartridge nozzles:
Using the computer:
  1. Load plain paper. For help, see Loading paper.
  2. Open the Lexmark Solution Center. On your computer, click Start menu > Programs / All Programs > Lexmark 4300 Series > select Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print the document again to verify that print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Using the control panel:
  2. Press Menu. The menu appears.
  3. Press the down arrow button until you highlight Clean Cartridge. Press Select.
  4. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Aug 15, 2011 | Lexmark P4350 All-In-One InkJet Printer
My Driver diskette isn't working any more so i can't use my ux-1400 in conjuction with my PC.
Download an updated driver on www.sharp.com, sharp UX B20 fax, download driver, and follow instructions.
Dec 01, 2009 | Sharp UX B20 Plain Paper Inkjet Fax
Have a sharp model UX-B20 but no manual to set it up to print
Not that hard to find; always check the mfr.'s website and look for 'Support.'
UX-B20 manual
Click on your model number to pen the .pdf manual which can then be copied to your local hard drive.
Sep 05, 2009 | Sharp Office Equipment & Supplies
Sharp fax machine ux b20 won't display ready to fax. Can not send a fax
I called Sharp and they said if the paper was feed properly (and it was), then the problem is with the fax sensor and the machine needed to be serviced
Aug 20, 2009 | Sharp UX B20 Plain Paper Inkjet Fax
Sharp UXB-30 Fax Machine
I'm not familiar with this unit. Make sure you are using the original cartridges and not "compatibles." They claim to be the same but they are not. There are some that are fine but their consistency changes all the time. If you are using the right cartridges then it may be the head that's clogged. The head in your unit may or may not be replaceable. If it's a bad clog, the cleaning process will not help. Manually cleaning these nozzles is not recommended because they can be damaged easily.
May 07, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
OEM cart dries out daily
I wonder if the problem might just be the cartridge is not up to the standard of the sharp ones?
Nov 08, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
Sharp UX B20 Plain Paper Inkjet Fax Logo
104 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
