Question about Senco & Frame Pro 601 Framing Nailer
Framepro 601. Works fine until air is disconnected then reconnected again, then it won't shoot and just discharges out the top 'vent' (not the exhaust). Some kind of safety lock is sticking?
  • 142 Answers
Sounds like lack of lubrication. Lack of lubrication builds up crud inside. Take the 4 Cap screws off the top of the gun (pay attention to how stuff comes out or you screwed). Carefully, turn the gun over and let the piston fall out. Now you can wipe some of the gunk out of the cylinder. Put it all back together, put about 10 drops of pneumatic tool oil in the air input fitting and spray up the nose of the gun with WD40 or some type of dry lube.
This should take care of it
Posted on Jul 28, 2009
  • Michael Wehr
    Michael Wehr Nov 27, 2013
    That is the same thing mine does ...cleaned....wd40...oiled....all you can do to lube the thing but as soon as you diconnect air line it sticks
Air leaking out of top vent; replaced driver, now nothing works
the top vent is the exhaust and usally leak from exhaust is trigger valve not seated properly if new ( oring s like to roll) or if not new sometimes internal spring breaks not having constant pressure on valve allowing to leak through exhaust.
Aug 12, 2015 | Air Tools & Compressors
My all gas oven flame goes out while cooking after about 10minutes and the stove top burners also turn off! Looks like I'm out of gas but im not. It's does this sometimes then works fine for a month then...
Check to make sure the burner gas discharges are all clean and none of the holes are clogged up. Then make sure the air intake vents are all clean and clear so its getting enough air.
Mar 10, 2015 | Kitchen Ranges
Senco pro frame 601 just blows air when trigger is pulled
Senco nailers are mostly not lubricated but moisture and dirt do they have the neck compressor not tapped in time and then inside the top cover of this tools can have that or the parts are hanging can not move freely and clean, solvent them out and grease it with silicon OKS1110 Kluber Silubrin or Dow Corning DC4 in most cases the models of Senco are oilless IF the seal of the piston is made out of kevlar instead of a plain o-ring .
Jan 20, 2014 | Senco 1G0003R FactoryReconditioned...
My dryer is smoking and making a noise
This is not good and should be disconnected from power source until problem resolved. It sounds like an accumulation of lint in the dryer base, where motor / belt compartment are located. Vacuuming all the lint from inside the cabinet will reduce the risk of a lint fire. Cleaning the exhaust / vent hose all the way through to the outside of building will allow better air flow. I have used a leaf blower to do this. Disconnect the dryer hose from the back of the dryer, and insert the leaf blower nozzle. Secure hose to leaf blower nozzle as best you can so it is air tight. Switch on the leaf blower for half a minute or so. Any accumulated lint in the dryer vent line will be discharged to the outside of building. Reconnect dryer hose to dryer and test to see if clothes are now drying faster.
Jan 07, 2014 | Frigidaire GLER341A Electric Dryer
While charging on AC works absolutely fine. But while discharging i.e. Running on battery, shuts down unexpectedly. The same also happens when the the AC adaptor is plugged out at random. Lastly, the...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 10, 2011 | HEWLETT-PACKARD ProBook 4520s
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Senco Framepro 602 has air coming from the top of the gun when the trigger is pulled and will not shoot the nails.
Sounds like the bar that slides down to push the nail is jamed you should disconect it from the air and check to make sure a nail is not stuck you should be able to look at the gun and see how to disasemble it in the front end to release it once that is done try some white grease on the part befor you reasemble it
Nov 20, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Framepro 602 only shoots air out a hole in the top when the trigger is pulled, occasionally shoots a nail but more often just shoots air
You have some worn out o-rings in your gun. Get a Senco repair kit #YK0360, use everything in the kit and your gun will be as good as new. Type "senco yk0360" in your search engine and shop around, the kit should be around $45 - $50.
Oct 11, 2010 | Senco Air Tools & Compressors
Senco &  Frame Pro 601 Framing Nailer  Logo
539 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
