Question about Dryers
I HAVE A KENMORE 110-67082600 DRYER AND I AM GETTING F44 CODE
I HAVE A KENMORE 110-67082600 DRYER AND I AM GETTING ERROR CODE F44 THE DRYER SHUTS OFF BEFORE CLOTHES ARE DRYED. DH
Can you please send us the diagnostic paperwork that you have for F 44 code.
Posted on Nov 05, 2011
  • 1,000 Answers
The F44 fault code indicates a blower motor control electronics failure. This can be caused by a wire harness connection problem between the machine electronic control board and the blower motor electronic control board. You will normally need a technician to diagnose and repair this type of failure. If you have the technical ability to safely access and check internal components in your dryer I can include the diagnostic portion of the manual.
Let me know.
Regards,
Posted on Jul 28, 2009
What does F44 error code on Kenmore Elite model 790.4890 mean?
You may be missing a digit in the model number. I believe that this microwave was built by Electrolux for the Kenmore line. The F44 error indicates that the external cooling fan for the microwave is spinning too fast. This can be caused by a blockage. Check if there is anything blocking the airflow. Make sure that the voltage coming into the microwave is correct. If your voltage is too high, then the fan will spin faster.
The fan is part 108 on this diagram: http://www.searspartsdirect.com/model-part/79048903000/0583/0125400/r1009032/00003.html . It's at the back of the deflector at the top of the microwave. This is the diagram for the 790.48903000 .
If there is nothing wrong with the fan (spinning normally), then the problem is between the fan speed sensor and the control board. This should be fixed by a professional.
I hope this helps.
Jul 15, 2016 | Kenmore Microwave Ovens
Error code F44 on sears kenmore elite oasis electric dryer.Doesn't seem to be cycling completely.
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
May 08, 2010 | Kenmore Elite HE4 Electric Dryer
What does f44 code mean
F44 indicates faulty motor blower controller.
The part is available here.
Jan 23, 2010 | Kenmore 67082 Electric Dryer
HI I HAVE A KENMORE ELITE OASIS ELECTRIC DRYER MODEL 110.6708 I KEEP GETTING A F44 FAULT CODE WHAT IS THIS FOR ?
44 flashes if the motor control detects a low voltage condition.
This error code could also be caused by poor air flow, loose wiring harness or a malfunction of the electronic control board.
You can disconnect the vent hose from the back of the dryer & compare that airflow to the airflow at the outside damper, they should be almost the same.
If you have a multimeter and the ability to safely check the voltage at the dryer outlet, you can check for 120 volts at the outlet for the dryer.
If the voltage is low or drops when the dryer is running, this is causing your problem.
You could have a loose wiring connection.
If the outlet voltage is okay, you could have a wiring connection problem between the outlet and the control board of the dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 04, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
How do I open my Kenmore Oasis Dryer to fix the F44 error? I've seen that it might be a loose connection since the error is intermitent. I'm not sure how to get access to panel.
Remove 2 screws in each of rear upper corners.
Slightly pull the front panel forward about 1/2" to disengage clips.
Remove the shell.
Jul 09, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Error message F44 in a Kenmore Elite Dryer. What
F-44 indicates a faulty blower motor controller. $169.00 from sears
or about $115.00 from an appliance parts store. Also note: the
service technicians repair guide is usually folded and tucked inside the top of the dryer console. It contains all the F codes and disassemble and reassemble and testing instructions. Part # for the service guide is (W10035270).
Mar 31, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
HC error code 110.27087603
Washer...check the pump unit and your manual...should have a code listing in there
Nov 25, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer shows f44 error
007, F44 is a motor control electronic failure. Couple of things you can try. 1. Unplug the dryer for 1 minute. Plug it back in and see if the error stops. 2. Under the consol there is a 3 wire harness that runs between the two control boards. Try reseating this harness. If that doesn't work, you will either have to call for service or do some detailed trouble shooting. Catriver, post back.
Aug 17, 2007 | Kenmore 67082 Electric Dryer
Dryer shut off
simply find out what F44 represents.
Jul 21, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
408 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
