Question about Boating
Mercury 115 problems
I have a 1990 mercury 115. Goes forward fine, but grinds in reverse. The prop turns, but only slowly even if you idle up.
  • 677 Answers
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Posted on Aug 01, 2009
1998 mercury outboard 40 hp serial #331450 will not fully engage reverse need to learn how to adjust shift shaft for it to fully engage reverse
unless you have the lower unit apart then it is not the shift shaft that is problem but the cables are not adjusted properly
Apr 09, 2018 | Mercury Cars & Trucks
1995 mercury 150 horse runs great idols great but very slow .when put in reverse quits seems like to slow idol . what screw do i turn for fast idol
Seems like your are describing a outboard motor. If so, the Boat section of Fixya may have more experts that you need. You would want to avoid turning any screws on the carburetor body. The externals on the linkage have some adjustments like throttle stops.
The linkage on boat shift mechanisms are tempermental. They usually combine 2 functions on 1 control lever. They are synchronized that when the transmission shifts from neutral to forward and neutral to reverse the idle speed is low. This keeps the gears from grinding and takes the shock out of the shifting process.
Another thing different than on a car engine is the effect of the propeller on engine rpm. You can change the "in gear"
rpm for both directions by changing prop size and/or pitch.
This also means you can over-rev the engine by having the wrong prop on the boat. There are engine rpm "stops" for the high end too, but some just rely on using the correct prop. As what you may be experiencing with a "stall" can be brought on by
A word of caution. The inboard/outboard engines can have the same problem as outboard engines. The shift levers are synchronized with a pivot system and adjusting the throttle can interfere with the shifting.
You may be able to view youtube videos by searching for these topics.
Mar 01, 2018 | Mercury Cars & Trucks
I have a 1986 mercury outboard motor, thunderbolt ignition, 50HP, 4 cylinder. Forward gear works great. Reverse gear works very slowly , moves boat very slow and weak. Appreciate any help.TY
there is no gear box as such in an outboard leg it is just a clutch dog that is slid from front to rear to engage the cogs attached to the prop shaft
the related gear forward or reverse is attached to the shaft with a drive pin or splines
you will have to pull the unit apart to find what section has failed as it appears that the cog on the shaft is slipping ( sheared pin or failed splines in cog)
Mar 28, 2017 | Mercury Boating
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
Mercury outboard 70 hp 1987 when in forward gear the prop turns one way when in neutrel spins both ways when in reverse the prop is locked both ways is my lower unit working property
mercury and others have a "sawtooth" cut for forward gear so the prop will rachet spin backward when dry tested, and a square clutch dog for reverse, which when it finally engages locks the prop in reverse. and will not spin in either direction.
So when you shift--- snap in in gear-- do not ease it in gear, as it will wear the dog out faster.
Sep 27, 2012 | Boating
Mercury 25hp will not shift into reverse sometimes.
If you have a control box, your shift cable end may be loose. It is swedged on to the connector and can break there, then stick, so check for a broken cable by holding the engine end when some one tries to shift it. If it pulls loose, you need to inspect it for breaks and loose anchors or connections.
If it is a manual shift, you may have a connector screw loose or missing. There is a posiability the shift cam in the lower is worn, or the center rod running inside the prop shaft is worn to the point it won't catch the clutch dogd. (shift quick/ don't rattle into gear.)
Most mercurys natural state was in forward gear, as they ate their clutch dogs you could get a little more service from them by under adjusting reverse- giving forward a little more life. It was a marginal fix and could end up with your problem.
Sep 17, 2012 | Seloc Mercury Outboard Engine Repair...
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
Boating Logo
335 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
