Question about Dell (E210882) Motherboard
My motherboard out of a dell optiplex gx260 the board it self is part number ASSY-3M537, I want to put it in a atx case I am worried it won't work. on the board I don't see how to hook up the power switch and reset switch? do I have to have a dell case? please help!
  • Dell Master
  • 4,806 Answers
This should be the front panel header configuration of that particular motherboard.
6-8 (red) is your power sw
2-4 (green) is your power LED
1-3 (yellow) is your HDD LED
5-7 (purple) is your reset sw
black is not connected
The motherboard should go into a custom case no problem.
Regards.
Posted on Jul 28, 2009
  • Delta aja Nov 27, 2010
    my connector are 33 pin,where's the power switch..?Thanks before..
Can i change out the motherboard on my dell dimension 4600 and use the one from my optiplex gx 520 in place of it.
No you can't. The Optiplex system board is a BTX type, and the Dimension uses an ATX style. The BTX board was supposed to be the new standard, with the layout changed to improve cooling air flow. Unfortunately, the I/O connectors (keyboard, etc.) aren't in the same place as on ATX boards, and you can't just drop the BTX board into the same case. (This is one of the reasons the new design didn't catch on. Seems people didn't like the idea of shelling out for a new case as well as the board.)
May 28, 2011 | Dell Optiplex GX520 (XG309) Motherboard
Can not install video driver dell optiplex gx260 windows xp sp2
moz-screenshot.pngThis has a nice board and your video board is possibly AGP type.
Find the manufacturer of the VGA board and download the appropriate driver if available for XP.
I hope this helps.
THis link may help.
http://support.euro.dell.com/support/edocs/systems/opgx260/en/ug/sysbrd.htm#1100517
Feb 17, 2011 | Dell OptiPlex GX260 PC Desktop
Will dell optiplex gx260 dewsktop pc support 512 mb agp
If you have the slim line version then you must buy a slimline card. Be careful ATI cards for some reason on gx260 and gx270's have issues and dont work. You can read about that on the dell support boards.
May 18, 2010 | Dell OptiPlex GX260 PC Desktop
Will a dell gx280 motherboard fit into a gx260 (dell) case?
If it is a slim gx260 case, it might not. If it is the wide case, it will, but the two motherboards have different power supplies. You will need to use a gx280 power supply to power it on. However, you can use a gx270 motherboard in a gx260 case without changing the power supply.
Hope this helps!
Oct 26, 2009 | Dell OptiPlex GX260 PC Desktop
Bios chip mother board
what do you need from the bios chip motherboard?
well if in case you will need some info about it just go for the documentation from dell found in the link below...
http://support.dell.com/support/edocs/systems/opgx260/
Nov 04, 2008 | Dell OptiPlex GX260 PC Desktop
Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Sep 24, 2008 | Dell OptiPlex GX260 PC Desktop
An old Dell Optiplex gx260 just won't turn on
Possible failures are:
  1. Powersupply failure
  2. Motherboard failure (Check the capacitors for popped ones)
  3. Front I/O Panel
Sep 01, 2008 | Dell OptiPlex GX260 PC Desktop
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Dell (E210882) Motherboard Logo
1,957 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
