Question about Dometic Rooftop RV Air Conditioner
Compressor won't kick off
Our dometic duo therm compressor will not kick off after the fan stops and the compressor freezes up.
I have the same issue.....the compressor come on any time power is provided to the unit....fan works fine..
Posted on Aug 14, 2009
  • Dometic Master
  • 6,674 Answers
What happens when started in just fan mode? Sounds like relay stuck.
Posted on Jul 28, 2009
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Undependable compressor
outdoor air sensor loose connection.
Jun 06, 2014 | Dometic Rooftop RV Air Conditioner
Outside temp was 113, the compressor stoped fan stayed on.Only hot air. Latter in the day compressor and fan worked fine. Should I be concerned ? Thank Mike duo therm 13500 .no heater
It just got so hot that the unit kicked out on high head pressure...
Check the outside condenser coil for dirt... wash it out with soap and water so that you can get maximum air flow through it...
Air Conditioning - Cleaning the Condenser Coil
heatman101
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Sep 01, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Apr 13, 2009 | Dometic Rooftop RV Air Conditioner
Have Duo Therm roof mount A/C. Fan runs but when compressor tries to come on it just has a hum sound for about 10 seconds then after a short period of time it tries again but will not kick on
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Feb 25, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Apr 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
465 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
