Question about Pentair Minimax NT Heater
Mini max 150 has pilot lit but will not heat
Unit is 4 years old. Pilot light is lit. Both stats will work by change in resistance. I have voltage thru the series of water sensors in the header. But the main burners will not ignite.
Could it be the pilot sensor or a stuck gas valve? Thanks
    President:
  • Pentair Master
  • 1,378 Answers
If you read Ohms across the TH circuit with the thermostat(s) turned up and the switch in the on position with the pump running you should have about 1.0 Ohms. Anything higher than 2-3 Ohms and you have too high a resistance reading and will need to find the bad part/connenction. If you have about an Ohm and the burners are not lighting be sure you have enough voltage off the generator. With no call for heat it should read around 500mV. Once you turn everything on it should drop to about 300mV.
If all these reading are correct try striking the gas line near the valve. The solenoid may be sticking. If it frees up you may get more use from it. If not, the valve needs to be replaced.
Posted on Jul 28, 2009
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
Dyna glo ra18lpdg pilot won't stay lit.
would have to think the thermocouple need replaced or the pilot flame is not big enough
Jan 31, 2015 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have switched my unit over to heat and only cool air blows out. Is there a reset button I can try before calling out a repair man.
It depends on what type of unit you have if it is gas or electric. If it is gas your pilot light is probably not lit .take the top door of your furnace off look under the burner and see if there is a small flame lit . if not it is simple to light turn the knob on the gas valve to pilot then push in on the know while holding a match at the pilot head to find the pilot head trace the small aluminuim pipe from the gas valve to where it ends that will be the pilot head once the pilot lights count to 10 slowly then switch the knob to the on position and your set make sure the t-stat is in the off position before lighting the pilot light.
If it is electric heat strips or a heat pump there is nothing to do other than turn t-stat to heat and make sure all 220 breakers are in the on position.
Nov 16, 2010 | Weather King Heating & Cooling
Pilot light lights, yet I can't seem to get unit to light off.
it may be a weak pilot flame or a bad thermocouple you can tesst the thermocouple should be 30mv or disconnect pilot tube from valve and blow pressure thru to clear. or have a service company look at (probably the safer option)
Nov 29, 2009 | Air Purifiers
Have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
Have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
Pentair Minimax NT Heater Logo
227 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
