Question about Logitech S 510 Remote Control, Multimedia Control Panel, Keyboard and Mouse
Logitech keyboard on linux-driven machine.
Problem fixed (almost). I looked in the repositorie and found some packages build to let internet-keyboards work properly. The only thing I have to do now is to build and install Wine (Windows emulator) in order to use the software that came with the desktopset.
Thank you for your help.
Johan Bruynooge.
Dear sirs,
I did what I should have done before posting the problem.
I retrieved some packages out of the build-in repositorie,
and now most of the function-keys are operateble.
However, to solve the rest of the problem, I have to
build and install Wine (the Windows-emulator in order
to to use the cd-rom that came with the keyboard.
Thanks for your concern in this matter.
Johan Bruynooge.
Posted on Jul 29, 2009
After installing kodi 16.1 jarvis ..getting message kodi has stopped working !!!
There is a possibility that you have your cache filled up on kodi. You can clear cache on kodi by following the given steps at the end of this post. Secondly you can setup best kodi builds to continue smooth streaming.
Clear Cache on Kodi:
  1. Open Kodi Jarvis > Then click on System menu in front of your screen > Now select File Manager > Double click Add Source option at the bottom.
  2. Once you click on Add Source, a box will soon appear where you need to click on 'None' option and type http://srp.nu/ > Click Done > Type URL Name below 'Super Repo' > Click Done > Then click OK.
  3. Once you are done, go back to Kodi Main Menu by pressing 'Esc' button on your keyboard > Go to System > Then select Add-ons > Then click on Install from Zip File > Super Repo > Then select Jarvis > Click on Repositories > Superrepo > superrepo.repo.0704.zip
  4. Now select Install from Repository > Then Super Repo Repository [Jarvis][v6] > Go to Add-on Repository > Select SuperRepo All Repository [Jarvis][v6] > Hit Install
  5. Go back two steps and click on Install from Repository > SuperRepo All Repository [Jarvis][v6]> Program Add-ons > Merlin Wizard > Install
  6. Open Merlin Wizard, go to Tool Box option > Here you will presented with 3 options i.e. Clear Caches, Delete Packages, and Delete Thumbnails. The space that each of these options consume are also listed below these options.
19 Best Kodi Builds To Experience The Colors Of Kodi
Sep 07, 2017 | Televison & Video
I lost my build on kodi 17, I help with retrieving it
In order to backup Kodi build you will need to go for the pre installed backup addon or you can install with the following method:
Select SYSTEM
Select ADD-ONS
Select INSTALL FROM REPOSITORY
Scroll down and select KODI ADD-ON REPOSITORY
Select PROGRAM ADD-ONS
Scroll down and select BACKUP
Select INSTALL
Wait for ADD-ON ENABLED
Once it is done, try to install 19 Best Kodi Builds To Experience The Colors Of Kodi
Aug 14, 2017 | Televison & Video
A rectangle with a star has appeared saying i need to configure some thing
Its hard to tell because each version of Linux has its on special files that it can download. Look in all of your applications and see if you find a program called Synaptic Package. All you have to do is click on it and it goes to the repository and will update all of the packages and its dependent packages automatically. Not all versions have Synaptic, some just say Software manager, but its the same thing. So if you loaded Skype off of the Internet then you probably don't have all the files as Linux does not work like Windows. You can look for the Terminal window to open and type sudo apt-get install Skype see if that works, but again, if the program did not come from the specific repository then it may not update. If you want to remove it then you can either find it in your file manager program (again in applications) and delete it. Or you can try sudo apt-get remove Skype. Third option is to right-click on it and see what options you get if one says cut or delete then you know what to do. The sudo options will ask you for a password which you should have, its the root password. Last solution is to reload and start over, I've done that more than once :).
May 28, 2011 | Acer Aspire One PC Notebook
As always you can find answers to your questions at www.xerox.com/support
Solutions for : Enter up to 64 Characters in the Shared Name Field Message is Displayed When Setting up a Network Scanning Template Using CentreWare Internet Services (CWIS)Related Fault Codes: 016-782 Solutions ranked by relevance Solution : Modify the User Login Name to a User that Only Exists on the SMB Server Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
Hope it helps!
Jan 10, 2011 | Xerox WorkCentre M128 Copier
I have just brougt my toshiba laptop not long ago but i found that some of the keys on my keyboard are not work properly..keys 8ik,and 9ol. the things is they are in raw aswel...keys iokl,. sometime do...
Most laptop keyboards do have the same problem regardless of the model. The keyboard gets the heat from the processor below which if gets high, short circuits the plastic sheet in the keyboard which caused the issues. The best way to avoid it up a certain extend is to introduce an insulator such as a cardboard sheet, etc under the keyboard while installing the new keyboard. Hope this helps.
Jan 03, 2018 | Lenovo Keyboard
I want to download music software but it wont let me
What you need to do is set your software repositories. Go into Synaptic Package Manager and select Repositories from the Settings Menu. In the Ubuntu Software tab, select all of the checkboxes under the "Downloadable from the Internet" heading. For good measure, you might also want to select all the checkboxes under the Third-Party Software tab as well. This should allow you to download more than just the purely open-source/GNU software that is usually enabled by default.
Oct 17, 2009 | Canonical Ltd. Ubuntu
Two grey blocks with a sun character in their center.
Its hard to tell because each version of Linux has its on special files that it can download. Look in all of your applications and see if you find a program called Synaptic Package. All you have to do is click on it and it goes to the repository and will update all of the packages and its dependent packages automatically. Not all versions have Synaptic, some just say Software manager, but its the same thing. So if you loaded Skype off of the Internet then you probably don't have all the files as Linux does not work like Windows. You can look for the Terminal window to open and type sudo apt-get install Skype see if that works, but again, if the program did not come from the specific repository then it may not update. If you want to remove it then you can either find it in your file manager program (again in applications) and delete it. Or you can try sudo apt-get remove Skype. Third option is to right-click on it and see what options you get if one says cut or delete then you know what to do. The sudo options will ask you for a password which you should have, its the root password. Last solution is to reload and start over, I've done that more than once :)..Well hope this helps, if you have any questions let me know.
Don't foget to rate this solution before logging out.
Jan 25, 2009 | Aspire Computers & Internet
Wireless laser mouse 5000 model 1058, manufactured march 2008
I found a website that offers the LR6 AA batteries that you were talking about and maybe purchase online. They look like regular AA batteries to me, but I am providing the link for you to view and make your determination. I hope this helps.
If you would not mind doing so could you please rate my help, I would appreciate it. Thanks
Jul 04, 2008 | Microsoft Wireless Laser Desktop 4000...
RE : Xerox Work Centre M128 016-782
May 19, 2008 | Xerox WorkCentre M128 Copier
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Output:
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks 192.168.1.0/24 and 192.168.2.0/24. Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src 192.168.1.0/24 192.168.2.0/24
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
Output:
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
Output:
tcp 0 0 0.0.0.0:3128 0.0.0.0:* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Output:
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Nov 26, 2007 | Computers & Internet
Logitech S 510 Remote Control, Multimedia Control Panel, Keyboard and Mouse Logo
53 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
