FixYa.com
Tags:
Gateway 7405GX PC Notebook
Gateway 7405gx boot failure
posted by djiembefola on Nov 22, 2007
I have a Gateway 7405GX that started having boot problems over a year ago.
At first it was a very sporadic problem but over time happened more and more.
As I recall, it would not boot and give an error regarding the boot device; I could hit F1, enter BIOS setup and then exit and the system would boot fine. Running a chkdsk showed no errors.
So, for a year or so I would use the system this way, until the problem advanced to a point where I can’t get into BIOS or boot.
I figured the BIOS or mobo was the problem and replaced the system. Lately I’ve started wondering if it could be as simple as replacing the CMOS battery, something that seems relatively inexpensive.
I feel like I never got my money’s worth out of this machine and it’s the only machine I’ve got that’s compatible with my Protools setup, but want to fix it myself and don’t want to spend hundreds on it.
Any ideas MUSC appreciated.
Thanks!
Dan
Comment by djiembefola, posted on Nov 23, 2007
Code
Thanks for the great tip.
I will definitely try this!
Cheers
Dan
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Code
Rank:Master Master
Rating: 92%, 17 votes
Hi Dan -
On this particular Gateway series of laptops, there is actually a bios "chip" you can replace entirely. It's sitting in a cradle right next to where the keyboard connects to the mobo (square black chip, one angled corner). It's very easy to pop out and replace, and is definitely something I would try.
You can do a search on eBay for "gateway bios chip" and you should have some luck.
I hope all goes well.
Rating Locked! (?) djiembefola has rated this solution as Helpful
Solution #2
posted on May 03, 2008
Not Rated (0)
flashrob
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
similar problem...
listen to "startup post BEEPS" ...I get 1-4-2 which indicates bad memory chip...plan to upgrade to 1gb ...comes with 512 (only one slot)...so better to upgrade to 1 gb
flashrob
Comment by flashrob, posted on May 03, 2008
url below has the "post beep codes" ...only one that matches is the "phoenix codes"...
you may have to unplug and remove battery to and put battery back in and try "fresh start" to get the beep codes.
regards,
flashrob
file:///C:/Documents%20and%20Settings/BOB/Desktop/PC%20Hell%20BIOS%20Error%20Beep%20Codes.URL
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Laptops problems?
PC Laptops
Runtime Error! I can't use IE?
I installed windows live one... Answer This...
PC Laptops
Gateway MX6453 or MA3
I've had the same problem with... Answer This...
PC Laptops
HP 1 long and 2 short beeps
Hi i am having that problem...... Answer This...
PC Laptops
pavo
pomagajte molim vas!!!!... Answer This...
PC Laptops
md41349
did you managed to get around... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
