Question about Euro-Pro Irons
The iron was dropped which resulted in the Steam Button (C) and Continuous Steam Button Lock was dislodged from the handle. How do I disassemble the handle to restore the buttons to their proper position? Fred
  • fred_ruddell Jul 28, 2009
    While waiting for help I fixed the problem by releasing the plastic ties in the upper handle then used a small flat bladed screw driver to undo the front handle stay, then I used some 1/2 pieces of a cut CD to keep the two pieces of the handle loose enough to put the switch back in its holder. Reassembled the unit, it's now working fine. Could of saved myself the $US13 if I'd not been so impulsive to believe you guys would have an answer for me. But thanks any way.
    Regards
    Frederick
  • 10,865 Answers
Hi Fred,
The euro-pro irons are designed to be tossed when they break. That said, you may be able to disassemble the handle by gently prying with a piece of thin metal, a feeler gauge works for this application. Feeler gauges are available in any hardware store. The plastic parts are snapped together at the factory. There is no service center for these irons.
I would begin with a pair of pliers and try to gently reseat the dislodged buttons.
Posted on Jul 28, 2009
I have a troia 13005 steam iron it heats up fine the tank and filter seem fine but no steam when i press the button under the handle it makes a terrible noise
Hello Corrine Oliveira,
Well... That was pretty interesting... WARN people
to put on their PRIVACY "X" CLOAKS before searching
for YOUR steam iron...
ADULT education... but little else (sorry)
What you really need to consider...
- Is it a NEW PURCHASE...? (take it back)
- Have you ever even looked at the "manual....?
- How old/expensive was this THING...?
I could find NOTHING on the internet... but before
I would drop it in the RECYCLE BIN... I would try
descaling it (several times) with white vinegar...
Then go shopping for a NEW one (my opinion).
Carnac the Magnificent
Apr 29, 2018 | Irons
Tip
Disassemble?
I recently had a problem with the steam button. It somehow during normal use came off its track in the handle and was stuck down in the "slot". After several searches online and this site i tried a knife along all the edges trying to figure out how to disassemble the iron. Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.
on May 08, 2009 | Sunbeam 4214 Iron
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Russell hobbs iron
If parts are available yes
Nov 14, 2013 | Irons
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Irons Logo
70 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
