Unable to cancel program using start/cancel button
Where is the cancel button?
Most printers don't have a cancel button. You get to "cancel" by going into your computer START menu then selecting CONTROL PRINTER then select CANCEL PRINT JOBS. In the future, I found the safest way to avoid accidentally printing more than intended is to always select "Current Page" when ordering a print job.
I hope that helps.
Mar 03, 2015 | Canon PIXMA Office Equipment & Supplies
Hi there, I have a Euromaid WM5 and suspect it was overloaded as it stopped near the end of the cycle. We turned it off at the power as it wouldn't reset and couldn't get clothes out. It has been off...
I think, that if you want to cancel the program, you have to select correct program on selector knob. When turning the knob observe the display. When correct program is selected, it will show spin speed and temperature.
I have also managed to reset the machine by entering service mode. Turn it off, select Cotton program. While keeping Start/Cancel button pressed, turn it on. It showed E 05, then whole display started blinking. Using the same button it started spinning. After turning it off and on again, the machine was reseted.
Feb 21, 2011 | Washing Machines
Software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Can't upload photos
Just hit cancel then after that click on Start then My computer. Under removable storage you will see your camera there right click and click open. you can copy your pictures now and drag them into your hard drive.
Nov 26, 2008 | Kodak EasyShare V1003 Digital Camera
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
Acer notebook/laptop 5920G(acer recovery management)
its dangerous to stop e rcovery process . the software may get corrupted . downlaod it again from e recovery support section of acer.com /. got oto add or remove programs and unistalll the program and try re installing it again . e recovery is a system acritical processs
Dec 14, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
