Question about Consew Sewing Machines
It's a older PFAFF. I believe a zig-zag. Not a home but more an Industrial size. The only #'s I have right now r on the front lower right. 138-6/21-BS. Any and all Info would be greatly appreciated.
The table its on is like those I sew at work on, but it has a Consew 115V motor. It will work but I need a manual 2 give it the TLC it needs before I try 2 fire it up. It would make a great movable machine, outlet wise. I need a manual. Thanks, G
  • Consew Master
  • 5,300 Answers
Pfaff has many of there manuals here: . I found a manual for the 138 using the search option after clicking on the down arrow in the Machine Name box. The direct link to the manual is . However, the only place I see any reference to 6/21 is in the section on needles. (Some 138 models used a specific needle system.) I don't see any letter codes after the 6/21 in the manual.
I hope this helps.
Posted on Sep 13, 2017
    Top Expert:
  • Consew Master
  • 49,159 Answers
Try google search Google
Testimonial: "Thank U for the Info quick & helpful with sites included. Again, Thanks, G"
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
SOURCE: I have a Consew 230 can provide a manual
Posted on Oct 09, 2008
  • 71 Answers
SOURCE: service manual for a consew 106rb
Hope this helps! Let me know if it not the right manual, and I will find you the correct one.
Posted on Oct 31, 2008
  • 15 Answers
SOURCE: how to oil my sewing machine
Kenmore machines may have parts and manuals available on -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
Posted on Nov 20, 2008
  • 86 Answers
SOURCE: need manual for newhome triple zig zag model 888
they are available at
Posted on Jun 22, 2009
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
Mar 13, 2016 | Sewing Machines
How do I change needle position on my Pfaff 2044
Use the zig zag adjustment while in straight stitch to move the needle position to the left or the right
Feb 10, 2015 | PfaFF Sewing Machines
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Jun 03, 2012 | PfaFF Sewing Machines
1222 Pfaff can not adjust to a large stitch
Will need more info to help you. Is the white dot on the zig-zag dial still at the top? If not you will NEED (no way around it) a zig-zag dial rebluild. Most pfaff repair shops do not know how to do this repair, will need to find a 1222 expert.
This is my gess with what you have told me.
Hope this helps
Mar 31, 2011 | Sewing Machines
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
