Back to:
Tags:
Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Main vacuum suction won't turn off (by 2 users)
posted by reggie10 on Nov 22, 2007
When I put the vacuum handle in the upright position, the main vacuum suction will not switch over to the hose attatchments. If I pull out the hose to use the attatchments, dust come flying out of the main suction hose. HELP
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Nov 30, 2007
tsuction don't work
Solution #1
posted on Jan 23, 2008
Not Rated (0)
Kazong
Rank:Wiz Wiz
Rating: 84%, 153 votes
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on main vacuum suction won't turn off:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Eureka Altima Upright Vacuum Model 2996AVS...
I have no suction at the hose or the main vacuum part.....
how do i change the belt and the link is broken is there a...
I followed the solutions that are on here already but I...
We have checked for clogs and cleaned all the filters, but...
I have a Eureka Altima vacuum and can't get the dust cup...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
